Full Version: 2004 Mk1 1.8 Tdci Fuel Warning Light
rattyc5
where is it? does the actual pic of the fuel pump light up yellow or is it5 a red light above the the handbrake light.have took the needle right down past the empty line and no light came on. had to put diesel in eventually cause i didnt want to empty the tank as i understand that it is a problem with a diesel engine. beginning to think that the bulb may be blown, if so , is it easy to replace?
cheers ray
rattyc5
think i have solved it with the diagnostics test i found here[url="http://www.typetr.co.uk/motoring/ford-focus-tdci/ford-focus-dashboard-diagnostic-test/"]http://www.typetr.co.uk/motoring/ford-focus-tdci/ford-focus-dashboard-diagnostic-test/[/url] fuel light works but battery is only 11.2. heard it should kick out 14 volts.is this true?
alz
Hi, you should have around 14.5 at the battery when the car is running, this will tell you that your alternator is ok, the low fuel light shoud be orange.
