smiffy
February 28, 2012, 3:50 am
Hi all
I have a weird noise from the rear of my 2001 Focus Black edition.
It sounds like the brake shoes are rubbing on the drums. At low speed it sounds like a scraping noise and is heard once every wheel revolution. At higher speeds it disappears a bit but there is still a noise present.
I took off the back wheels and span the drums and they do sound noisy but i dont know if it is brake related or bearing noise.
About 2 weeks ago in the cold weather we had here in Dorset, whenever i applied the brakes from cold the rear wheels locked up!!! A few miles later they were ok.
I have always had strange things happening from the rear brakes on my Focus.......is it a known thing with them?
All help/suggestions appreciated.
Thanks in advance
Simon
February 28, 2012, 6:34 am
sounds brake related to me usually in these circumstances i would take the drum off and check the brakes and the piston,it could be corrosion inside the drum or a sticky brake piston. the fact they locked and freed up would suggest the piston
smiffy
February 28, 2012, 10:34 am
Thanks Artscot79. it does sound like brake shoes rubbing not a whine/groan like a bearing.
Can someone tell me the size of the socket i need for the rear hub nut? i have tried a 1 1/4(32mm) socket but it is too big. I know you can undo the 4 bolts at the rear but mine are pretty rusty and a bit rounded too
thanks
Simon
February 29, 2012, 7:22 am
rear hub, I dont know why but 26 or 28mm rings a bell?
February 29, 2012, 6:12 pm
It's 30mm for the rear hub nut, 13mmfor the 4 rear bolts.
I think artscot is on the money here, sounds like the piston or shoes/adjuster
smiffy
March 2, 2012, 4:53 am
Thanks for the replies.
Stef123 i think you are right with with 30mm. Took wheel off and measured the nut as well as i could it seems to be 30mm. i think a 29mm would fit too if you hammered it on tight.
Gonna buy a 30mm socket and have a look for myself........it's starting to really annoy me
rojariggs
March 2, 2012, 6:45 am
It's hard to describe but a brake rubbing is a "rougher" sound than a bearing. From your description, brakes seems likely.
smiffy
March 10, 2012, 3:43 pm
I had a look at my rear brakes today. When i removed the drum the top shoe return spring was just loose in the drum, ie not connected to the shoes at all. I guess some how it had come off. I think this was the cause of the rubbing noise but i dont know yet as i ran out of time today and will test drive it tomorrow. Anyway, i had to disassemble the shoes to reattach the spring. Is it just me or is the handbrake cable a complete bit$h to reconnect? Luckily i had another pair of hands to help me. I dont think i could have connected it back up otherwise.
Is there a specific knack to do this or am i just weak/stupid? haha
It just seems a bit of a daft design. Do ford mechanics use a special tool?
By the way i used a 30mm socket to crack the hub nut.
Simon
March 11, 2012, 3:54 am
[quote name='smiffy' timestamp='1331415785' post='171941']
Simon
did you loosen the handbrake cable at the adjuster first?
