I was huting for a nice flapped or retract pocket of some kind, but the cup holder ones on Ebay look nasty, the drawer only version was out of stock.
I got one for an MR5 but the front is a bit too small, the DIN cage shows around the edge, and i can't find a surround thin enough to fit.
You can get one for a Scooby, but after the MR5 one i'm loathed to get another that won't fit.
BMW ones are only for sunglases, and are tiny
I pondered something a bit fancier, my only clock is on the radio, and that stops me viewing the other MP3/RDS info.
if i wanted simple, i can get a DIN blank, cut it, and fit this flush inside
http://www.ebay.co.uk/itm/130584450962?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
This is a bit more work, it's too big to fit, but remove the case the LCD should fit in the blank ( if not remove the LCD from the board, then rewire to put the function buttons in the front
http://www.ebay.co.uk/itm/400234193308?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
DIN sized clocks... stuck in the 80's
http://www.ebay.co.uk/itm/290675578891?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Any other suggestions of things that'll fit in the DIN??
Nothing Kevvy, or that would be found in the chav section of halfords
yep, the ebay links suggest i want it cheap, so 700 quid double radio units that do everything are out of the question
