modorion
March 4, 2012, 9:58 am
hiya everyone just windering if you can help me i have a orion 1.6 ghia and have two problems for the mot
1. revese lights not working checked the bulbs they seem k.
2. brake pedal can be moved side to side to much play
if you can help it would be much apreciated cheers
Z3 MON
March 5, 2012, 7:52 am
1) check the plug/switch for reverse lights, its either on the gearbox or under the gear lever.
2) firstly check the bolts are tight down there, if the are then a new assembly is required which can be sourced from any good motor factor
