AndyHerrington
March 6, 2012, 11:22 am
Hi All,
I am new to the Ford Owners Club and wanting some advice,
I have a 58 plate 2.0tdci Zetec SMax, I got in it today to do the school run and as I set off an Engine Malfunction warning came on the Dashboard screen along with the amber traction controle symbol on the dash and the traction controle off light above the stereo, I had no loss of power as I was climbing a steady incline but pulled over asap and turned off the ignition, Went to start the car 30 seconds after and the fault had gone,
Could anyone shed any light on the problem?
Andy
AndyHerrington
March 6, 2012, 12:13 pm
Just an update,
Found this code Dtc#01 C41668
Any Ideas?
137699
March 6, 2012, 2:39 pm
No idea on the DTC code but could be an ABS sensor or toothed ring.
Do you have cruise control? If so, is it still operational?
AndyHerrington
March 7, 2012, 2:03 am
No Cruise control, just a bog standard Zetec,
Going to ring Frauds up, sorry Ford, (slip of the tongue) to see if they can enlighten me,
AndyHerrington
March 7, 2012, 3:27 pm
[size=5][sub]Update[/sub]
[sub]Rang local Ford dealer, Explained what had happened and the DTC code from system test, They said I would need to bring it down to dealership so they can plug it in, £75 to plug it in but they were unable to do it until next Wednesday, So I rang Ford's main customer service center who were unable to help but gave me Fords technical helpline which was a premium £1 per minute call center, explained to their technical support worker for 5 minutes and he explained the code that was flashing up on my Smax wasnt any of the codes they have, and was put on hold whilst he went to check another system, 10 mins later he returned with the following explaination[/sub][/size]
C41668 = U0416-68
U0416 = Invalid Data Received From Vehicle Dynamics Control Module U0416 = Invalid Data Received From Vehicle Dynamics Control Module
68 = DTC Failure Subtype definition for failure category “6”. 68 = DTC Failure Subtype definition for failure category "6". Event information — This subtype is used by the control module to indicate the detection of a system event that was not caused by the control module itself but forces the control module to store a DTC (eg missing functionality from another system/control module). Event information - This subtype is used by the control module to indicate the detection of a system event that was not caused by the control module itself but forces the control module to store a DTC (eg missing functionality from another system / control module).
unquote
I Asked what that meant in english and he said i could have a faulty sensor on my ABS,
Hallelujah!!!!!!!
I asked is this a common fault
Reply "It can Be"
