Hi Everyone, i have recently bought a Transit Connect and noticed a bit of a diesel smell in the cab. on further investigation i noticed a wet patch around the no.2 injector and after reading online about possible causes it turns out that it is the 'leak off' pipe that comes out of the injector. i took this apart and the o ring disintergrated on removal, i had a selection of o rings but the one i have found that is the correct diameter is too thick and just splits when i put it in. Does anybody know where i could buy o rings to fit? i have got a feeling i may end up needing to buy the whole set of leak off pipes so if this is the case does anybody know a good place to get these? Thanks in advance,
James.
