Full Version: Revving engine when clutch depressed
teaser
Hi all
Newbie here! can anyone help, I have just purchased a KA 1999 for my daughter.
When approaching say a roundabout & de-press the clutch - the engine revs for approx 3 seconds then settles down to idle ok
Can anyone shine any light on this
Idle control valve sticking???
Many thanks
Ian
Jax
Hey there I have got exactly the same problem on my 2000 studio KA. I really have no idea what is causing it - does in happen on all your gears? And is it on long or short journeys?
richard64
[quote name='Jax' post='12436' date='Feb 17 2009, 09:34 PM']Hey there I have got exactly the same problem on my 2000 studio KA. I really have no idea what is causing it - does in happen on all your gears? And is it on long or short journeys?[/quote]
Ford know about this problem, I am told it is something to do with the powertrain control module signal.hope this point you in the right direction
tankie22
[quote name='teaser' post='10777' date='Jan 28 2009, 10:40 PM']Hi all
Many thanks
Ian[/quote]
[url="http://i10.photobucket.com/albums/a119/Tom106/KaEngine.jpg"]http://i10.photobucket.com/albums/a119/Tom106/KaEngine.jpg[/url]
The throttle control valve is the silver thing with wires just to the left of the centre of this image. Take it off, and the thing that its connected to,(black plactic mount) and clean it with degreaser, or wd40,
Ford do know about this but they will replace more parts and charge your... coz its not an actual recall.
The cleaning takes about 20mins plus drying time, and works like a charm. You only need one spanner for 4 bolts.
tiz
clean out the idle control valve had the same problem with my fiesta
gaz6076
Like it was said in previous posts it is a common problem known by ford.
This is fords recomendation;
Problem - engine idle speeds high during gear changes and/or impression of sticking throttle
Cause - Incorrect throttle position sensor signal due to poor multiplug connection
There is a modified throttle position sensor wiring harness/multiplug which can be baught from ford if you want to get is sorted properly
Part no. for the harness/multiplug is 1 150 138
eurofordka
[quote name='teaser' post='10777' date='Jan 28 2009, 11:40 PM']Hi all
Many thanks
Ian[/quote]
hi i can help with that i had the same problem on my 96 model and i stripped the throttle body down and took the butterfly out cleand it and put it back n it worked fine hope this helps u
