Full Version: Mondeo Tddi Cutting Out Problems
Jonnie Jenkins
hi all i hope some one can help with this ongoin problem on my 51plate mondeo tddi ghia x
a while back the car started cutting out the glowplug light flashes if i wait a second then restart the car iw would run fine.
this happened once or twice in about 8 months (went to france and back twice with out it doing it)
recently its started happening more and more so i got a guy out with the snap on diagnostics machine wich couldnt detect a fault so decided to buy a f super diagnostics machine using formidable software and heres the codes im getting
p1665 injection pump control module communications
p1608 watchdog malfunction
p0335 crankshaft position sensor a curcuit
so i changed the crank sensor!!! still the same so i bought anouther and changed it again STILL THE SAME
had a lood at the wiring around the fuel pump and crank sensor and that seems ok.also changed the fuel filter
but the car is getting worse just drove 14 miles and it did it 8 times so now getting realy annoyed
has any one come across this problem before or know how to fix it
thanks in advance
swhite87
i'm not sure if its the same engine but i had the same problem on my focus tddi, i changed the throttle pedal and problem solved might be worth getting one from a breaker just to see if it sorts it or not
