Full Version: Radio Aerial Help
mitch84
Hi
Since owning my Focus Mk2.5 at times I have not been happy with the interference I get on radio stations , I only really listen to radio 2 and sometimes Capital , at times the quality is not that great , but not bad by any means , its just going from my fiesta mk7 the radio quality has defiantly dropped.
I have the Denso Touchscreen satnav display unit , but I'm unsure weather others find the radio quality a bit rubbish in general on the focus?
I'm thinking about trying another aerial , has anyone changed there's , if so any thing I should go for?
cheers
mitch84
unscrewed the antenna today and the thread had a bit of corrosion , sprayed some electrical contact spray on it and brushed off , may do the trick.
salsheikh
keep us posted how you get on. mind you i replaced mine with a dab unit and aerial (new aerial and wiring) but still get inteterference and it can gt annoying).
mitch84
[quote name='salsheikh' timestamp='1333110858' post='175151']
did you have the denso satnav as well? , is this unit not DAB?
ide use some copper grease on the ariel threads trust me they stick solid after a while i just had to change the ariel and base 2 months ago as it snapped thats 3 winters on 2 different focuses ive had its happened crappy ariels so i got a race x extendable bee sting ariel with built in amplifier definately better than the old one when its just the stubby add the extra long section and its perfect
mitch84
Hi
Just an update , still getting bad interference on my radio , its not constant interference but it happens a lot when you dont expect it , so disappointed with it , I would like to try cleaning the contacts which I heard were above the centre light , is this easy to remove and check for any corrosion ?
thanks
salsheikh
Steve,
i have the Ford/sony DAB unit and get interference still - something no reception/sound at all.
removing the light is easy, just pull it down and you can see the aerial base. there is a DAB replacement guide in ford wiki page that shows you how you replace the aerial. cant post the link on here so google is your friend.
mitch84
Hi
Today I purchased a Ripspeed aluminium aerial from Halfords , just fitted it and I'm very pleased so far!
[url="http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_376731_langId_-1_categoryId_165622"]http://www.halfords....tegoryId_165622[/url]
On the way to get the aerial I had minor distortion every 30 seconds or so , after fitting the new aerial I have had no interference (although I only had the radio on for 5mins on my short trip) but its looking good.
Not only has it possibly solved my radio interference it looks a lot smarter than the long focus aerial , the new aerial comes with 3 different length rods , I used the longest length which is about 25cm.
cheers :)
ajt
A lot of poor reception issues are down to the fact that the factory fit base is not earthed correctly to the car body. It relies on a lock washer cutting into the paint work and making contact with the metal work of the car body (this is behind the roof light).
I found on mine (I could only get signal from local radio), that the earth was not making contact. I had read about people scraping some paint away, but I don't fancy that (worried about rusting). So I use a ring crimp and connected a short piece of wire to a nut and bolt, net to the aerial, assume earth for lighting. Reception is now great, get all the channels now.
NorthSussex
[color=#0000ff][size=5][font=comic sans ms,cursive]On my previous Mondeo I had a similar problem, and it turned out to be a poor connection to one of the spark plugs causing arcing, but not effecting the engine performance.[/font][/size][/color]
Full Colour Version: Radio Aerial Help
