Full Version: Slow Moving Steering Noise (Rubbing)
soulman123
Mk 1.5 ff 1.8 04 petrol 50k
Hey all :)
Bit of an odd problem basically when I reverse into a bay slowly moving the steering wheel there is this kind of best described as a rubbing noise like rubber..
Also if stationary I tried moving the steetin wheel a quarter turn and it makes the same noise.
Hopefully I have not been too vague in describing thid.
Any ideas what it might be or the likely suspects ?
On a brighter note it passed its mot last week with 2 advisories. Rear trailing arm bushes perished but not causing excessive movement.
thanks for any help *thumbs up*
STEADS
have you got mud flaps fitted ? could be catching on lock
soulman123
Hi stoney,
Thanks for the post.
I do have mud flaps. I have had a look and are not rubbing.
Usually there is no full turning when I park, mainly drive in to bays but I do reverse in for a speedy exit.
I wonder if it has anything to do with the drop links.
NorthSussex
[color=#0000ff][size=5][font=comic sans ms,cursive]It could be the Aux / steering pump belt needs adjusting.[/font][/size][/color]
NorthSussex
[size=5][font=comic sans ms,cursive]This thread seems to be running in two places. <_< [/font][/size]
spray the rubbers top and bottom both sides of the drop links and wait 5 mins then try again if the noise goes you have youre answer
NorthSussex
[quote name='artscot79' timestamp='1334305343' post='177357']
[color=#0000ff][size=5][font=comic sans ms,cursive]WD40?[/font][/size][/color] <_<
yeah meant to write that just off a niteshift been up 20hrs going to bed
soulman123
Apologies for the double I clicked post twice as it didn't seem to be doing anything or my impatience after a hard day.
I'll give the wd40 a go. I hope the if it is them I can easily change them, I have a basic tool kit, trolley jack, stands, sockets the core essentials.
It did just pass it mot but I know drop links can be hard to diagnose unless you take them off and check movement.
Interestingly the drivers side was changed when I got the car so I guess the suspect side would be the passenger side. Unless they used a cheap part on the drivers side which could have failed. I think under the rubber is a balljoint which should be fairly stiff if its floppy its done.
I hope it is that. Not sure of the procedure to take off but on previous cars it was just 2 nuts and off it comes.
Thanks for the help :)
Standard procedure is to change both sides at the same time, it keeps everything nice and equal.
soulman123
Ahh I guess the forecourt I got it for decided to be cheap.
A likely suspect seeing as the drivers side failed, I bet the passenger side was mot far behind.
That will be my first port of call.
When I get in ill get the Haynes out to see what's involved.
