[quote name='Lenny' timestamp='1334409224' post='177581']
your high oil level isint just oil content but is normal
its your DPF has gone through a cycle of burning off the suit from the filter,
when doing this it takes some oil and diesel, mixes it with the eloys fluid and burns the suit with it,
then whats left gets put in to your sump where it drains out on your next service, all diesels with DPF are the same and mine is high too,
ive booked mine in for a service at the end of the month for the oil etc. to be changed but this is all normal operation,
but it will dilute your oil and leave it not as good as it once was at lubracting the engine due to it being diluted with fuel but its the way they are designed to operate and out of our hands.
These DPF'S are a disgrace. So not only are they expensive to replace and NEEDLESS, they also damage the engine, pollute the sump,give poor performance to the car,cause huge amounts of headaches to owners by having to replace them or the engine breaks. Is there one,just one good thing about these DPF's?
