Full Version: Tddi Problems
kc..
hello to all,,,, ive just got back from having my tddi 115 01 plate plugged in as goes in limp mode as soon as you start the car, its come back as fault code p0110 air intake wiring malfuction, as anyone had any sort of problems like this ???
After having a good look over the car and ive noticed that theres a black plug which plugs into the long black plastic intercooler hose underneath neer the radiator, im imagining that its some sort of sensor,well the wires which run ito the plug look as if they have been rubbing on the chassis and look damaged would this be anything to do with my problem ?
it seames like you have found the problem as the wires most likly run to the map sensor which monitors air flow in the intake.
kc..
Thanks for your reply buddy, so do you think that if the plug is damaged/wire snapped it would cause the car to run like it does, no turbo, no accelleration
kc..
i have had a go at this today an it was the map sensor plug it had smashed and broke the prongs, how ever when i started the car afterwards it was still the same but if i turned ignition off and on again whilst driving it seemed to reset itself and drove as good as ever but as soon as i went to change gear or let off throttle it went back to sluggish mode, would it have to plugged back into computer to be reset ??.
you could try an ecu reset by disconnecting the battery for 30 mins, but make sure you know your radio code first.
kc..
Had it plugged back in and code is still there p0110 it wont let you delete it either.. grrrrrrrrrrrrrrrr
Could it be air flow meter or is there any other sensors i could start changing..
kc..
hello again, i still havent got any where with this guys its doing my head in to say the least, i still havent changed air flow meter yet located to the left of the air box, what i have done is took it out and give it squirt with wd40 and to be honest it looks ok but didnt make any difference,im almost sure the car runs no different if i unplug air flow meter,
kc..
[size=5][sub]Hi guys latest is ive been advised to check for circuit with mutimeter on map sensor, and maybe check voltage levels on mass sensor does any one have an idea what readings i should be expecting and with it being a 4 wire plug which wire is for what...???[/sub][/size]
kc..
right ive had the car running with live data and iat "intake air temp sensor" is reading values of -40 degrees with only ignition on key off now i know this is probably my problem but i cant locate the sensor, ive since heard that some iat sensors are part off the maf air flow set up ???? any ideas anyone ??
Full Colour Version: Tddi Problems
