Full Version: Mondeo 2011 Obdii Connector
Mike_R
Where do I find this? I want to reset the service indicator after an oil change. Thank you. Mike
You should find this somewhere around the drivers side, near the coin scutttle, it should be resessed into the dashboard.
Mr Ford
OBD plug is on the right hand side of the dash, open the little storage box then above that you'll see a little cover the obd plug is behind that. But you don't need to connect a scanner to reset service light. Turn ignition to ON (don't start the engine) then push the brake and accelerator down together and hold it down for about 30 to 45 seconds the display in the cluster will say "service reset in progress" then after a few seconds it will say "service reset complete" release pedals and the service light will be reset
Full Colour Version: Mondeo 2011 Obdii Connector
