MDESIGNMASTER@AOL.COM
February 2, 2009, 9:49 am
no power to turn engine on battery ok, when turned off fuel pump continues to run with no key in ignition at all.
is this a fuel or a immobilizer problem. can anyone help.
February 2, 2009, 11:28 am
when you say to turn engine on, do you meen the ignition lights or no power to the starter motor?
February 2, 2009, 1:19 pm
[quote name='MDESIGNMASTER@AOL.COM' post='11102' date='Feb 2 2009, 03:59 PM']no power to turn engine on battery ok, when turned off fuel pump continues to run with no key in ignition at all.
is this a fuel or a immobilizer problem. can anyone help.[/quote]
ALL IGNITION LIGHTS ARE ON WHEN KEY IS TURNED TO START CAR BUT NOTHING HAPPENS CAR IS JUST DEAD NOT EVEN A TURN OVER.
CAR IS 1800 LX VERONA PETROL AND YEAR 2001. XREG.
February 2, 2009, 1:20 pm
February 3, 2009, 10:29 am
sounds like you have no power to the starter which could be a loose or corroded lead, a knackerd starter or the immobliser not working correctley.
Bottlethroddy
February 3, 2009, 10:37 am
[quote name='mintalkin' post='11185' date='Feb 3 2009, 04:39 PM']sounds like you have no power to the starter which could be a loose or corroded lead, a knackerd starter or the immobliser not working correctley.[/quote]
I agree, but if you say the fuel pump is continuing to run even with the key out of the ignition, i would be looking at the immobiliser first
February 4, 2009, 12:44 pm
[quote name='Bottlethroddy' post='11189' date='Feb 3 2009, 04:47 PM']I agree, but if you say the fuel pump is continuing to run even with the key out of the ignition, i would be looking at the immobiliser first[/quote]
HAVE NOW HAD CAR CHECKED BY AUTO ELECTRIC . SHOWING FAULT AS ANTENNA ON IMMOBILISER AS FAULT IN PROCESS OF GETTING NEW IMMOBILISER ANTENNA TO BE FITTED.
MANY THANKS FOR YOUR HELP.
