Full Version: Central Locking Issue
billy880
hi guys
when locking my focus via the push button key the car locks itself fine BUT then unlocks straight away, if i lock the car by inserting the key in the drivers door, the whole car locks fine
really annoying!
ive checked all doors are shut so i dont know why this has just now happened??
any ideas on fixing? whats causing it, is it an easy fix?
A central locking solenoid not firing will cause all the doors to unlock again as the cycle is not completing.
Listen to each door in turn as you remote lock and you will probably hear one not running.
It will either be the solenoid gummed up or corroded from water ingress via the window seals or a damaged wire in the umbilical connector to the door.
billy880
[quote name='Stoney871' timestamp='1334770042' post='178387']
hiya
since i posted the topic ive been outside trying to sort it, its wierd cos i went straight outsidet after posting the original topic and it all worked fine by the key!! i then opened the bonnet to check my oil and when i closed the bonnet and pressed the key to lock, it started unlocking again!
i sat in the car and the drivers side does seem abit quite than the rest of the doors etc, but you can here it functioning......
what ive noticed is, is that if you lock the drivers door manually with the key so then all doors are locked, then unlock the car via pressing the key THEN lock the car via the key it works! but if i open the door and shut the door, then press the key to lock it will unlock straight away! so i have to lock the door via the key then unlock by pressing the key, then lock again pressing the key!
Most likely a dry connection in the wiring then.
Full Colour Version: Central Locking Issue
