rivnog
April 25, 2012, 3:51 pm
I've got a focus tdci 52 plate with a slight leak of coolant coming from a plastic hose fitting bolted to the engine block with 3 bolts in a triangle shape.
The plastic fitting is located by the dip stick it has a single large diameter hose coming out of it in a downwards direction at 45 degrees.
Sorry for my poor discription but, My question is does anyone know what the fitting is.
davidmt57
April 25, 2012, 5:29 pm
hi, from what you have described it sounds like it is the thermostate housing. the parts are not to expensive but can be a bit tricky to fit
rivnog
April 26, 2012, 1:02 pm
i think your right it is the thermostat housing. Going the try some Bars Leak stopper first. Then maybe a local garage
rivnog
December 15, 2012, 3:10 pm
leak stopper worked for about 3 months but it's started losting water again.....
I've now got a thermostat housing from a local breakers cost £10 so i'm going to have a go over christmas.
I assume there is a gasket that goes between the engine and the housing?
