mickeyboy
May 2, 2012, 6:13 am
hi the wifes got a focus 18 zetec instument panel going haywire and on start up the batterys boiling any idears .........xxxx
May 2, 2012, 8:19 am
smart charge has gone and putting major amps into the battery causing it to boil do the dash test and check the voltage it shouldnt be above 14.5 i suspect youres is far above that looks like a new alternators needed also make sure the battery is silver calcium not lead acid as this will also cause the battery to boil see here http://www.petercoopercarrepairs.co.uk/ford_focus_alternator_smart_charging.htm
