Full Version: Flip Key
Drich290195
Anyone no how I can convert the standard mk2 key fob to the flip one cheers guys
johnH
ive seen this done with peugeot keys....not too sure if it can be done with the ford keys though
This is how i did it-
1. Buy this key from this trader (trust me the keys are brand new and will work perfectly) - £29.95
[url="http://www.ebay.co.uk/itm/FORD-3-BUTTON-FLIP-KEY-FOCUS-C-MAX-S-MAX-MONDEO-NEW-/200750003533?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ebda1f54d"]http://www.ebay.co.uk/itm/FORD-3-BUTTON-FLIP-KEY-FOCUS-C-MAX-S-MAX-MONDEO-NEW-/200750003533?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ebda1f54d[/url]
2. Call a local Auto Locksmith and they will cut, code to your ECU and set to your central locking in about 20 minutes.
Don't take any guff about the key metal being too hard/will blunt blades or any other lame excuse, they will cut just fine, i have been using my flip key from this dealer for 9 months with absolutely no problems at all.
Do not try Timpsons as they refuse to cut this type of key because they're useless and incompetent and would only clone the key anyway rather than adding it to the ECU properly.
I got mates rates on my key cutting/coding (£20), i know standard customer rates will be higher but still way cheaper than your local main dealer will charge and also make you wait at least an hour so they can charge a labour rate on top of the cutting/coding and they usually push a diagnostic (£99.00) on top of that too for good measures.
Drich290195
Is their no way I could get one drone a scrappy and do it that wat
ferretfloozy
nope keys have to be added to the ecu ..its part of the security ..if you lose a key you have to have the lost key removed from the ecu before you can add any further ones..stoneys advice is the only way to do it ..earlier models it was possable to add keys by inserting exisiting keys in a set equence(you had a red master key)..but trust stoney on this .. his advice is the only way to do it correctly ..timpsons are for shoes and watch batteries :D
Guys,
ive got a new flip key for my 2010 focus mk2.5
im going today to get the key blade cut to match the other flip key and regular key that i already have for the car.
i have programmed the new flip key to operate the central loking by pressing the buttons on the fob,
and im getting the blade cut today,
what do i do to get the ecu to communicate with the key,
can i insert the otehr two keys followd by the new one?
ferretfloozy
thats what i thought i could do .. the keys have to be inserted in the correct order ..i.e the original will be coded as number 1.and any extras will be 2..3.. etc .. i tried this but it didnt work so an auto locksmith had to code it for me .. its part of the anti theft system .. if a key is lost then that key must be manually removed fom the ecu so it cannot be used to start the car ..the new key will then take its place in the order sequence .. the old method was to use the master key then re-code all the existing keys to the immobiliser by inserting one after another.. the central locking fob is not coded with ecu... i ended up doing what stoney has done ..only difference was mines a 3 button fob not the flip type ( or you can swop the transponder in the old key over )
+1
On the MK1/1.5 you could add keys yourself using the 2 original keys that came with the car, but on the MK2 and later models that ability was removed.
I know that the transpnder can be swapped from one fob key to another with care, but i'm not sure if the transponder is the same shape in the flip key.
In the fob key the transponder is attached to the fob part but on flip keys the transponder is in the blade part.
The only way to get to it is to dissasemble the blade part but doing so may knacker it beyond use.
My tame Locksmith did tell me that the transponder chips in the flip keys can only be programmed to one car, so buying a second hand/scrappy one is not advisable, unless you are able to verify that you can swap an existing active transponder between keys.
went down to the locksmith today and he has refused to cut the blade on the flip key for me,
because i didnt purchase the key from him and he asked where i purchased the key from and i said i got it from ebay for 25euro, he said ''thats not possible their must not be any electronics inside the key since it only cost 25euro''
i then informed him that it has the electronics inside because i have activated the central locking to function on the car,
so i just need to get it cut and he said ''im not cutting it because you didnt purchase the key from me and i dont trust the supplier that you purchased it from, i recommend you go back to ford with the car and the keys get them to do it for you, or i can supply a flip key to you for 150euro and ill cut it for an additional 10euro ''
so i left the shop very unhappy
Just their excuse to get money from you.
Robbing buggers.
[quote name='Stoney871' timestamp='1336834828' post='182231']
Robbing buggers.
shame it went that way though lol
all i want is my key cut ive had it almost two years now and i just need it cut.
i bought one of those keys and took it to a local company that do the programing for dealers he checked my key out then told me info, ford send the keys to be cut to him and that key is a genuine ford key exactly what they use he cut it no probs that was a tenner then he coded it using his computer thing 5mins and 20quid so 30total to cut and programme. i told ford i wouldnt need it dome at their 180quid for key and cutting and programming they were not happy when i told them how much it cost me
[quote name='artscot79' timestamp='1336845013' post='182258']
nice one mate,
but my local for dealer is 148km or 92miles away from me so im not even going to get a price off of them,
i think ill ask richiemac where he got his key blade cut because i travel up north on occasion to visit family and i could get it cut on the way up their, if he can tell me where he got it cut.
DaveD
Flip key...pahh give me an ordinary key any day. This 'flip' key from Ford (or should I say FIAT) is not good. Much too bulky and what is the point of unlocking the boot only??? I ask you.
Better than jabbing yourself in the nads every time you bend over with a fixed key in your pocket.
Wayne Brian Pearsall
[quote name='Stoney871' timestamp='1336856646' post='182288']
lol thats why i took my car key off my house keys... easier to carry my car key in my pocket and not be stabbed then my 4 house key set... (i have the "hidden" key for titanium...) - love the keyless entry....
I always keep my house keys seperate from my car keys.
I don't like the idea of losing them all in one go.
ferretfloozy
i dont get that problem .. keys are in my handbag :P
[quote name='ferretfloozy' timestamp='1336896022' post='182330']
being male,
id rather get jabbed in the sack,
than carry a handbag but some may choose the handbag option lol
How about a fetching man bag?
[quote name='Stoney871' timestamp='1336906663' post='182351']
not really my style lol not even a bum bag
I believe you ;) honestly i do. :P
[quote name='Stoney871' timestamp='1336923610' post='182385']
lol [url="http://www.focusowners-social.com/forum/posting.php?mode=smilies&f=38#"][img]http://www.focusowners-social.com/forum/images/smilies/292.gif[/img][/url]
Getting very worried about you now.
[quote name='Stoney871' timestamp='1336923956' post='182389']
no need to worry mate,
im a true ladys man not a lady boy :D
so he says but weve seen what you do with plastic and gaffer tape lol :D
:P
[quote name='artscot79' timestamp='1336939974' post='182441']
[url="http://www.focusowners-social.com/forum/posting.php?mode=smilies&f=38#"][img]http://www.focusowners-social.com/forum/images/smilies/ymca.gif[/img][/url]
[url="http://www.focusowners-social.com/forum/posting.php?mode=smilies&f=38#"][img]http://www.focusowners-social.com/forum/images/smilies/butbut.gif[/img][/url] lmao
Very very worried now.
[quote name='Stoney871' timestamp='1336941336' post='182447']
[url="http://www.focusowners-social.com/forum/posting.php?mode=smilies&f=98#"][img]http://www.focusowners-social.com/forum/images/smilies/closet.gif[/img][/url] [url="http://www.focusowners-social.com/forum/posting.php?mode=smilies&f=98#"][img]http://www.focusowners-social.com/forum/images/smilies/icon_lol.gif[/img][/url]
Now I'm scared too.
Full Colour Version: Flip Key
