suddste
May 16, 2012, 10:59 am
Hello,
I think my alternators slowly dying, had a battery warning light on the dash when i was entering a roundabout today. When I got home and turned all electrical things on to test, I had a voltage of about 10.5V. THe heated front screen seems to take the most power and with this the headlights are dim
My question is: On changing the alternator, you have to remove the drive belt, but do you have to take it completly off of everything (like the AC compressor) or can you just unhook the belt from the alternator by hand then put the belt on the new alt.
May 16, 2012, 12:16 pm
you dont need to remove the belt completely, chances are though it will fall off the pulleys so make note of how it routes
suddste
May 16, 2012, 12:25 pm
[quote name='stef123' timestamp='1337188592' post='182892']
thanks and im just a bit worried about having to jack the car up and remove the front tyre for the alternator replacement. do I have to do any of this to replace the alternator? If I do, I just wont be confident in doing it
May 16, 2012, 12:27 pm
[quote name='suddste' timestamp='1337189117' post='182895']
no you should be able to do it all from above. there are 3 bolts holding the alternator IIRC. the top 2 with the torx ends are what tension the belt, slacken all 3 but remove the top 2 and the alternator will pull forward.
suddste
May 16, 2012, 12:32 pm
Excellent, I will be very happy if I manage to do it myself..The only thing im worried about is if I mess the belt up because the power steering is powered via this also
May 16, 2012, 12:34 pm
[quote name='suddste' timestamp='1337189548' post='182900']
make a quick sketch of how the belt is routed just in case it comes off. disconnect the battery first, you dont want to short out the positive terminal to earth with a spanner!! its quite an easy job actually.
suddste
May 16, 2012, 2:13 pm
[quote name='stef123' timestamp='1337189649' post='182901']
Do you know what tools I require? I know it's torx but not really sure what sort of torx i'm looking for here
May 16, 2012, 3:25 pm
[quote name='suddste' timestamp='1337195603' post='182919']
basic spanners and sockets. its a female torx socket or spanner you will need but i cant remember the size
suddste
May 16, 2012, 3:40 pm
[quote name='stef123' timestamp='1337199908' post='182938']
thanks. so just take out the top two bolts with a spanner, then loosen the bootom bolt, then push sideways to the left? AM I correct?
May 16, 2012, 4:04 pm
[quote name='suddste' timestamp='1337200838' post='182941']
pull the alternator forward, this will release the tension on the belt. then remove the bottom bolt. remove the electrical connectors first though
suddste
May 16, 2012, 4:33 pm
[quote name='stef123' timestamp='1337202245' post='182950']
thank you
suddste
May 21, 2012, 7:31 am
Hello,
Just had a look at how I could remove the alternator...
Are you sure it can be done as you said? It doesnt seem possible to me and I dont think the tension on the belt can be slackend by loosening the screws, it's a mk1.5 1.6L Zetec-SE with air conditioning
May 21, 2012, 9:54 am
[quote name='suddste' timestamp='1337603479' post='183641']
Hello,
Can you post a picture up?
Mine was also a 1.6 Zetec SE. the alternator pivots on the lower bolt, the top to pull the alternator in and this also pulls the belt tight
suddste
May 21, 2012, 11:15 am
[quote name='stef123' timestamp='1337612052' post='183661']
sure, here it is:
suddste
May 21, 2012, 7:28 pm
any ideas?
May 22, 2012, 10:07 am
[quote name='suddste' timestamp='1337646534' post='183772']
any ideas?
Its the same as what mine was. remove the hex head bolt, loosen the bolt at the bottom and then use the stud to release the tension.
suddste
May 22, 2012, 10:22 am
ok, thanks
suddste
May 26, 2012, 6:25 pm
[quote name='stef123' timestamp='1337699275' post='183815']
sorry I have to ask another question. Can you just use a spanner to loosen or do you need torx also (for all screws)?
May 28, 2012, 3:34 pm
[quote name='suddste' timestamp='1338074758' post='184352']
you only need torx to turn the stud, apart from that its hex spanners
suddste
May 28, 2012, 3:48 pm
[quote name='stef123' timestamp='1338237287' post='184544']
ok so I definatly need torx to complete the job
suddste
June 9, 2012, 11:50 am
Just tried to turn the nut at the top. It's rock solid I cant get it to turn. Any ideas on how to get it loose?
Andy 1965
June 9, 2012, 12:44 pm
Spray it with WD-40. Leave it for 24 hours and try again. Do not attempt to loosen it with the wrong size of spanner/ bit. If it is still stuck, apply heat by means of a blow lamp and try again.
suddste
June 9, 2012, 2:01 pm
[quote name='Andy 1965' timestamp='1339263897' post='186494']
thanks
June 9, 2012, 5:05 pm
try a longer ratchet or spanner. if you dont have any try doing the trick where you join 2 combi spanners together.. ring end on the bolt, and put the ring end of another spanner on the open end. gives you twice as much leverage
