Full Version: Ford Escort Rear Brake Drums Removal
smoothdriver108
Hi
Ford Escort 1.6 Zetec '96, I can't remove the rear brake drum , ihand brake is off, the drum spins freely but it won't come off .There is no grub screw. Is there a trick to this ?
Help appreciated.
oilburner79
Have you undone the 32mm hub nut?
smoothdriver108
No, Haynes did not mention removing it.
frund
I have the same car and the nuts have to be removed to get drum off. The nuts look difficult. and may need special tool and new nuts to go back on ?
mickminnion
First thing is to loosen the drum where it has become stuck to the hub. On the outward facing edge or periphery , the drum is reinforced. A few smart taps with a hammer should lossen this bond. The next thing is that once the drum starts to move, it may become jammed on the brake shoes. All you can do here is to try and ease it past the shoes, it often helps to try and rotate it at the same time, but the shoe steady pins might become detached as well. Before replacing the drum it is often advised to carefully remove the wear ridge on the outer lip of the drum. This is normally done by the careful use of an angle grinder or you could do it by hand with a coarse file.
Greetings from the North Pennines and Hadrian's Wall.
smoothdriver108
Greetings mickminnion, thanks for that.
