bluearmy
June 12, 2012, 9:35 am
Hi all,
Focus Cmax 2004 1.8 petrol
My car has started losing oil at an alarming rate. Was serviced 9 months ago. Last month I took it it as handbrake had come loose. They checked oil whilst it was in and said it was empty. So they topped it up for me for cost price of course.
I havent notice any oil on my driveway so I rule out a leak.
Anyway, as it happens I have just had rev problems and took it in again and was told its the manifold or something and its going to cost £60 just to get to the problem and see what it is. Thats not my main concern at the moment though. The oil was almost gone again. And its only been a month...
I noticed some smoking a couple of times this month but nothing persistent. Garage told me that it could be the start of major engine trouble and I should get rid as soon as possible. It only has 40k on clock.
Could it not be something simple? Maybe a seal somewhere? Or am I to bite the bullet and try to get shot of it? I am really short on cash at the moment so I am low on options....
Any advice would be welcomed.
thanks for looking
Dan62
June 12, 2012, 10:20 am
A stuck PCV valve maybe ? This would cause excessive crankcase pressure forcing oil past seals. Other than that, yes, its going to be some expense finding the problem.
Check and topup the oil frequently yourself, if it runs OK using a few gallons of cheap oil a year stick with it, at least you won't have to ever do another oil change !
There's probably some additive you can buy but i wouldn't suggest you try it until you know the crankcase is properly ventilated.
D.
bluearmy
June 12, 2012, 10:58 am
[quote name='Dan62' timestamp='1339514422' post='186980']
D.
Would it cost me to actually get the garage to find the problem? I assume like the manifold issue I have, that they will charge me labour just to locate it. If they locate it at all that is........
As for refilling the oil on a monthly/bi-monthly basis, was that a serious suggestion? Or more tongue-in-cheek? It would certainly be a cheaper option thats for sure....
Thanks for reply
June 12, 2012, 11:24 am
if the engine is burning the oil, you need to work out how its getting into the cylinder.
if its the valve stem seals, take the car for a run, get the oil hot and leave it overnight. have someone start the car up for you next day while you stand at the rear of the car looking for blue smoke
as above, excessive pcv pressure can force oil past the rings, but you might also have a worn/damaged ring or rings
Dan62
June 12, 2012, 12:40 pm
[quote name='bluearmy' timestamp='1339516713' post='186987']
Thanks for reply
[/quote] I don't know how accessible the PCV valve is on your engine, its not an expensive part which is why I suggested it.
As for being serious about keep topping up, yes, if you can't afford to get it fixed or replaced right now do whatever you can to keep it running, but obviously within reason (exhaust smoke or using more oil than petrol).
PCV Valve should be fairly easy to replace and if your having any work done around the inlet manifold area, that's about where it should be.
I'm sure the garage are thinking either valve stem oil seals or rings which would make a big hole in anyone's pocket but until you start stripping the engine down you cant say for sure if its either or both.
NorthSussex
June 12, 2012, 1:41 pm
[color=#0000ff][size=5][font=comic sans ms,cursive]Be good, and If you do PX your car let us know the Reg No so one of us don't get stuck with it.
[/font][/size][/color]
bluearmy
June 13, 2012, 11:22 am
Ok, so garage phoned me this morning and said some manifold pipe has split. £25+vat for new one. Is there a chance this could have caused my oil to disappear?
NorthSussex
June 13, 2012, 11:44 am
[quote name='bluearmy' timestamp='1339604550' post='187170']
[color=#0000FF][size=5][font=comic sans ms,cursive]Did the garage not say if that was the cause of your oil disappearing? Or do they have some other explanation[/font][/size][/color][color=#0000FF][size=5][font=comic sans ms,cursive] [/font][/size][/color][color=#0000ff][size=5][font=comic sans ms,cursive]?[/font][/size][/color]
bluearmy
June 13, 2012, 12:55 pm
I get the feeling they dont want to investigate it for some reason....
They said that the current repair wont sort it.
Didnt really give me any clue. Just said they cant understand it, the engine sounds really good and looks in good nick with only 40 odd thousand on it.
Probably take it somewhere else for a look over when I get it back
NorthSussex
June 13, 2012, 1:57 pm
[quote name='bluearmy' timestamp='1339610143' post='187189']
[color=#0000ff][size=5][font=comic sans ms,cursive]Yes good idea, take it elsewhere. [/font][/size][/color]
