GSM
June 16, 2012, 5:07 am
Hi all,
I've got a 2006 Focus Ghia 1.6 and having some issues with the heated front windscreen.
Half of the screen seems to work (passenger side), whilst the other half doesn't work at all. I'm assuming that the mechanism is split into two circuits at some point and that the side controlling the drivers side is faulty/disconnected/fuse issue somewhere.
Just wondering if anybody knows where to look and how to test for problems?
June 16, 2012, 5:14 am
This is a common fault with the Focus.
There is a copper ribbon under the scuttle panel that gets caught by the wiper motor link and gets damaged.
If you search the forum you will find previous threads concerning the cause and solution.
June 16, 2012, 5:34 am
It might also be worth checking the connector under the scuttle.
When my mondeo screen stopped working on one side, I traced it back to a bad connection. Cleaned and tightened the pins, it's been fine since
NorthSussex
June 16, 2012, 6:38 am
[color=#0000ff][size=5][font=comic sans ms,cursive]I've also had the same problems on a Granada and a Mondeo, it's always the drivers side that packs up, it,s about time Ford sorted this one.
[/font][/size][/color]
June 16, 2012, 2:36 pm
also check the fuse for the non working side.
June 16, 2012, 5:22 pm
i had a look under mine and the copper wire is at the front on top of the metal not hanging under like the ones ive seen the wiper goes nowhere near so im not sure its been a ford issue.
NorthSussex
June 17, 2012, 3:07 am
[quote name='artscot79' timestamp='1339885378' post='187675']
[color=#0000ff][size=5][font=comic sans ms,cursive]I hope you're right Arthur, I would be miffed it it happened to me for a third time on 3 different Ford models. .
GSM
June 24, 2012, 8:30 am
It must be some sort of design fault given the frequency of the fault... seems to be everywhere! Might not be the wiper thing, but might just be the use of cheap/poor quality wiring.
NorthSussex
June 24, 2012, 8:45 am
[quote name='GSM' timestamp='1340544608' post='188773']
[color=#0000ff][size=5][font=comic sans ms,cursive]I agree, it happened on both of my last 2 Fords, drivers side packing up, fingers crossed for this Focus.[/font][/size][/color]
June 24, 2012, 10:28 am
the wiring sits right on top of the area where the rain runs down to the drain under the scuttle panel and gets a lot of muck on it the wiring looks like copper so should last.
had a look at mine just last week and alls fine where they are situated. it could be either when screens are replaced these ribbons are not sited correctly which is where the wiper gets it or some arent done at the factory.
2focus and no issue with either in laws c max no issues and both neighbours foci no issues all 2005 to 2007
NorthSussex
June 24, 2012, 11:10 am
[quote name='artscot79' timestamp='1340551735' post='188784']
[color=#0000ff][size=5][font=comic sans ms,cursive]That sounds reassuring.[/font][/size][/color]
GSM
June 24, 2012, 4:53 pm
Opened it up and had a look at mine today. The ribbon was completely detached from the wire - that's the problem. Not sure how it happened though, hard to see how it had been routed since they were just completely detached.
Soldered them together and are hoping for some good conditions to test it soon... although knowing my luck it'll probably be lovely and sunny with no steamy windows for a good while.
