dontmess
June 19, 2012, 11:26 am
Hi, need to remove some power steering fluid from my car as there is too much in the car at present.
I was planning on using a[b] plastic syringe [/b]to remove the excess liquid but just wanted to make sure that this was [b]safe[/b].. it won't contaminate the fluid or anything..
Thanks in advance for any responses
June 19, 2012, 11:28 am
If its clean it will be perfectly ok.
dontmess
June 19, 2012, 11:33 am
Cheers!!
tomo2001
June 20, 2012, 4:58 am
Use one of those syringes you get with kids medicine, they're perfect
June 25, 2012, 10:04 am
Any form of pipette should be fine, or if you pop to your local chemist (boots especially) and ask at the counter for a 5ml childs syringe, you can get one for 50p! you can then just take out the fluid in small goes so that you dont lose too much.
bt_cav
November 1, 2012, 9:30 am
Hi guys
just had a search for changing power steering fluid.
I looked in my Ford owners guide to find out what the correct fluid is for my focus (04 1.6 petrol) all it says is "Use ford power streering fluid meeting the ford specfication WSA-M2C 195-A"
Is this a Special fluid or can I use halfords own?
November 2, 2012, 9:14 am
I think as long as it abides by 195-A it should be fine
bt_cav
November 4, 2012, 3:18 pm
Cheers mate
I used Halfords Advance automatic transmission and power steering fluid. The specfication of this reads
WSS-M2C202-B
ESP-M2C166-H
no issues to report
soulman123
November 11, 2012, 8:10 am
Have you notice any difference in the power steering out of interest ?
bt_cav
January 23, 2013, 5:13 am
Hey mate sorry for the slow reply
Not noticed any real difference, I did think the 'knock' was not so loud but I could be wrong.
The 'knock' only happens during the first 5 mins while cold after that its gone...
I think to make any real diffrence I'd have drain out All the power steering fluid
However Im not sure the best way to go about this without getting air locks and pools of power steering fluid everywhere.
I was thinking of undoing the lowest pipe on the powersteering rack and collecting the fluid in a wide container of some sort??
January 23, 2013, 6:09 am
[quote name='bt_cav' timestamp='1358939602' post='229515']
Power steering is easy to bleed, all you need to do is full lock the steering each way a few times and that should be enough.
You could drain it that way or remove the return hose to the resevoir and catch the fluid from it as someone turns the steering and you keep filling it up. This will flush the system entirely of old power steering fluid.
bt_cav
January 23, 2013, 6:24 am
Nice one Stef, I thought there must be a better way of doing it
