Full Version: Streetka Door Handles Have Broken (Again) - Help
BetsCats
Help!!! That is, I've just pulled my door handle and it's not opening my door (it's now going back and forth without doing anything). This happened (for the third time in 12 months) 3 weeks ago....got it fixed (along with the drivers side interior and exterior handles, and it cost me £270 (for both doors - as it happened to both at the same time and I had to climb out of the window)!
I DO NOT want to take my car back in to get this fixed, so could anyone please tell me:
1) is there a way I can fix this &/or prevent it from happening.
2) is there a Streetka repair and maintaince manual available so that I can repair it myself.
3) if no Streetka manual is available, can I use the KA repair & maintaince manual - are the KA and Streetka door handles/etc the same?
Basically, if I can't deal with this myself, I am thinking about getting another car - as I cannot keep having this happen. (3 times in 12 months). I love my streetka, but I am completely gutted!
HELP!
Thx,
Betty
katbh
I know how you feel, this seems to be a consent problem with the Streetka. I recently had my passenger door handle replaced and bought the part off ebay myself then got a local garage to replace it for me which cost £40.00. I wouldn't advise doing it yourself as it's a really fiddly job you have to drill out and and replace revits on the side of the door. To prevent this happening I spray all my handles (inside and out) with WD40 every couple of weeks or so as they tend to get quite stiff which then causes them to brake. Hope this helps. :)
SandyCat
The problem isn't with the handle itself but where the cable goes inside the door behind a box to the door release.   Because the handle is weak it breaks when the cable has too much resistance.
I figured this out when ours became very stiff so I took the door card off the when I pulled the handle I noticed the plastic box move so clearly it's not big enough to house the cable as it pulls and turns and this puts back pressure on the plastic handle.
So I cured it by pulling the plastic box away from the door-it's sealed on - to give the cable more room to move.  And then spraying loads of 3-1 oil  (NOT WD40) inside the plastic box and all along where cable release travels helps it move without rubbing.
I can confirm that since doing this on both doors 2 years ago both handles still work normally without any stiffness.      Simply replacing the handles does nothing and they will soon break again.
