Full Version: Fuse Box And Fuse Number Equipment Info
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford C-Max Club
Neilc
Hi is it possible to get a list of what equipment the fuse controls, each fuse appears to be numbered in the fuse box but I cant find a list of what each one controls!!
Any help appreciated
Neil
The Focus fuses should be the same so i'll post the list when i'm at home later.
Neilc
Many thanks its mainly the A/Con fuse I am after but a list would be useful !!
Neil
I shall oblige.
To be continued.
[quote name='Neilc' timestamp='1340908632' post='189698']
Neil
if this is the engine bay fuse box then look under the lid of the fuse box their is a full diagram printed on it. [url="http://focusowners-social.com/forum/posting.php?mode=smilies&f=10#"][img]http://focusowners-social.com/forum/images/smilies/dancing_cat.gif[/img][/url]
Neilc
]Hi Sorry to both replys, I should have said its a 2004 Focus C Max and the fuse box is up underneath in the passengers footwell.
Here is a fuse list for passenger fuse compartment + FUSE Rating
F30 10a Light Switch
F3115a Audio
F32 15a Direction Indicators
F33 20a Horn,Seat Adjust
F34 20a Sunroof
F35 7.5a Intrior lights,electric motors
F367.5a Electronic modules,instruments,clock
F37 25a Electric windows
F38 25a Electric windows
F39 NOT USED
F4010a Reversing lights {Automatic Transmission}
F417.5a Radio {accessory},instrument cluster
F4215a Brake lights
F4315a Electric windows,rear wiper,switch illumination
F4420a Front & rear fog-lights
F45 7.5a Air con,recirc air
F46 7.5aABS module
F47 15/20aCigar lighter,accessory socket,trailer control
F4810a Diagnostic connector
F49 25a Heated rear scren
F50 7.5a Heated mirrors
F51NOT USED
F52 15a Heated front seats
F5310a Rev lights{Manual trans},heated washer jets,headlight leveling {xenons},cruise control
F54NOT USED
F55 25a Electrice front windows
F56 20a Front wipers
F57 7.5a RH side light
F58 7.5a LH side light
F59 10a Light switch
F607.5a Air-bag module
F61 7.5aElectronic modules,intrument cluster,clock
F62 7.5aNumber plate lights
F63 20a Central locking
Here is a list for the engine compartment fuse box + FUSE RATING
F1 40a Main power supply
F2 NOT USED
F3 40a Glow plug heater 2
F4 50a Heated front screen
F560a Diesel glow plugs
F6 30a Engine cooling-fan {air con versions}
F7 40a Main power supply
F8 30a Ignition
F920a Engine management
F10 1a Battery voltage sensor
F11 30a ABS pump
F1215aFuel pump,diesel injection pump
F1330a Headlight Washer
F1410a Parking-lights
F1510aAir con clutch soleniod
F1615a LH dipped beam
F17 15a RHdipped beam
F18 10a Lambada sensor
F19 NOT USED
F2010a Engine management
F2120aABS
F2220a Daylight running {xenon lights}
F23 20a Aux-Heater {diesel engine}
F24 30aGlow plug heater 1
F25 15a Daylight running {normal lights}
F2610a LH main beam
F27 10a RH main beam
F2810a Heated front screen,diesel fuel fired heater,diesel engine
F2930a Engine cooling-fan {air con}
F64 30a Heater blower motor
F65 30a Engine cooling fan
[u][b]List courtesy of Lenny[/b][/u](Thanks Mate)
Neilc
[quote name='Stoney871' timestamp='1340959523' post='189813']
F3115a Audio
F34 20a Sunroof
F39 NOT USED
F4215a Brake lights
F46 7.5aABS module
F51NOT USED
F54NOT USED
F2 NOT USED
F8 30a Ignition
F11 30a ABS pump
F19 NOT USED
F2120aABS
F2610a LH main beam
[/quote]Hi Many many thanks I will print it off and put it in the owners handbook for future reference
Neil
You are very welcome.
