Full Version: Help To Identify Engine Noise.
Ford Owners Club - Ford Forums > Welcome to Ford Owners Club > New Member Introductions
alfabloke
Hi All,
am a new member and have an issue with my pride and joy!
I have a mondeo st 2.2 TDCI, there is a bearing squeek or belt slip on start-up and turn off, also on low revs if the engine labours.
Anyone got any bright ideas or had the same problem?
could be a bearing or tensioner at fault. you will need to inspect the left hand side of the engine as you look at it.
alfabloke
[quote name='stef123' timestamp='1341337791' post='190742']
Thanks for the response, have had it in the garage but unable to pin-point issue, they have sudgested that it could be the master fly wheel and would be expensive!
[quote name='alfabloke' timestamp='1341338334' post='190746']
from what you have said it doesn't sound like the flywheel to me.
The crankshaft pulley has a tendancy to break up and makes a weird squeaking/chirping sound.
alfabloke
[quote name='stef123' timestamp='1341339052' post='190750']
thanks, would you know if its a major or minor problem?
[quote name='alfabloke' timestamp='1341339618' post='190754']
in the early stages its a minor problem, more annoying. I believe it can leak to crankshaft failure though, its meant to absorb vibration and act as a damper. if its really worn, you might be able to see the pulley vibrating - this can also damage the tensioner etc so its worth doing it all together
ford sell a kit for this, its made by gates so you could also source it elsewhere for less than ford prices.
Its a bit of an awkward job but 2 hours max to replace everything
see here,
[url="http://www.ebay.co.uk/itm/FORD-MONDEO-MK3-2-2-TDCi-ALT-BELT-KIT-CRANK-PULLEY-07-/160626895047?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item25661be8c7"]http://www.ebay.co.u...=item25661be8c7[/url]
alfabloke
[quote name='stef123' timestamp='1341339958' post='190756']
see here,
Thanks.
Full Colour Version: Help To Identify Engine Noise.
