soulman123
July 13, 2012, 2:01 pm
1.8 04 petrol
I have this slight knocking noise at slow speeds like in stop start driving and gentle braking and going over speed bumps. Today it sounded a little louder than usual.
It does sound like its coming from the passenger side.
I'm just wondering what this might be ? and where I should start looking ? hopefully there us some dry weather this weekend and I can have a poke around.
thanks
raskL
July 13, 2012, 3:39 pm
Chech the exhaust isn't loose could be rattling on something
tyler s
July 14, 2012, 1:08 pm
also check the anti roll bar links
Andy 1965
July 14, 2012, 2:19 pm
Nearside track rod end.
martyntdci
July 15, 2012, 5:42 am
as stated, anti roll bar bushes, wishbone, drop links, mayb tie rod, mayb cracked spring, loose engine mount, play in drive shaft. take ya wheel off just use a small jimmy bar on all steering componants, look for leaks, excessive bush wear etc...
btmaldon
July 15, 2012, 12:30 pm
Worn top mounts can do this. You get a knocking noise even when on a road that is only slightly uneven.
soulman123
July 17, 2012, 2:26 pm
Discovered the fault thanks to you helpful folks.
Took the drop link off, bottom balljoint was fine top one flopped all over the place. Also the balljoint rubber was ripped/split so no grease and exposed aswell.
I replaced it, a bit fiddly but done in an hour. Took it for a drive seems no noise. Will keep my eye on it to make sure it is gone. But so far so good.
Thanks a lot!
martyntdci
July 17, 2012, 4:31 pm
glad ur sorted dude
July 17, 2012, 5:10 pm
sometimes it can be an easy fix glad its sorted
July 17, 2012, 6:28 pm
Echo!!!
Sorry
