Full Version: Guide: Fitting Footwell Lighting To Your Ford
Pages: 1, 2
[b]Here is a Guide to fitting footwell lighting in the front and rear of your ford. [/b]
[b]also available in PDF format: [/b]
[b]For those who have the bulb holders in the front footwells but their is no power in them,[/b]
they should purchase[b] [u]Qty: [color=#FF0000]2[/color][/u][/b] of this Cable which would be 4 metres of cable. [url="http://www.ebay.co.uk/itm/Twin-Core-10A-amp-12V-Black-Red-DC-Power-Cable-per-2m-/170680456683?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bd5915eb"]http://www.ebay.co.u...=item27bd5915eb[/url]
cut the existing loom around two inches from the bulb sockets and fit this loom running the two sockets off the one single run of cable then up the A pillar and splice in to the blue and black cables at the rear of the interior light.
Blue = Positive +
Black = Negative -
alternativly if you do not want to cut or splice the existing loom, you can tape up the existing bulb sockets and fit some new ones, along with the cable and fit them istead.
also if you would prefer not to splice the loom at the rear of the interior light you can purchase an illuminated ignition ring which comes with pre moulded connections that fit in between the connection from the loom to the interiro light.
so you can fit the ignition ring and splice the footwell lighting in to the ignition ring loom instead of the actual ford loom itself.
the ignition rings are available on ebay and come in colours red,blue or white
[b]Below is an image of the loom on the ignition ring for you to get an idea of how they connect to the interior light:[/b]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1132-1.jpg[/img]
[b]For those who havent got the footwell light sockets or loom present in the front footwells[/b]
They need to purchase the sockets to fit the holes which are here [url="http://www.ebay.co.uk/itm/T10-W5W-194-168-Light-Instrument-LED-SMD-Bulb-Extension-Connector-Socket-Holder-/290682684249?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43ae09c359"]http://www.ebay.co.u...=item43ae09c359[/url]
plus the cable in the link above too.
finally for both fitments they will require some T10 w5w light bulbs of their choice.
[b]For those who would like to fit some Rear Footwell lighting [/b]
i have got [b][u]Qty [color=#FF0000]2[/color][/u] [/b]of these in red led pods fitted under the front seats of my focus,
one stuck to the top of the footwell blower under each seat facing on to the rear footwells and wired in to the loom of the front footwell lighting.
here are some links to the pods for the rear footwell's.
[color=#FF0000][b][u]Be sure to order Qty:2 in order to recieve two of them [/u][/b][/color]
[b][u]Red Pod[/u][/b]
[b][u][url="http://www.ebay.co.uk/itm/RED-LED-5-LED-POD-LIGHT-Wire-Attached-Motorcycle-Car-/350057941604?pt=Motors_Car_Truck_Parts_Accessories&hash=item5181144a64"]http://www.ebay.co.u...=item5181144a64[/url][/u][/b]
[b][u]Blue Pod[/u][/b]
[b][u][url="http://www.ebay.co.uk/itm/BLUE-LED-POD-5-LED-LIGHT-Wire-Attached-Motorcycle-Car-/350057941448?pt=Motors_Car_Truck_Parts_Accessories&hash=item51811449c8"]http://www.ebay.co.u...=item51811449c8[/url][/u][/b]
[b][u]Green Pod [/u][/b]
[b][u][url="http://www.ebay.co.uk/itm/GREEN-LED-POD-5-LED-LIGHT-Wire-Attached-Motorcycle-Car-/350057941573?pt=Motors_Car_Truck_Parts_Accessories&hash=item5181144a45"]http://www.ebay.co.u...=item5181144a45[/url][/u][/b]
[b][u]White Pod[/u][/b]
[b][u][url="http://www.ebay.co.uk/itm/WHITE-5-LED-POD-LIGHT-Wire-Attached-Motorcycle-Car-Bike-/350057941637?pt=Motors_Car_Truck_Parts_Accessories&hash=item5181144a85"]http://www.ebay.co.u...=item5181144a85[/url][/u][/b]
[b]Here is a guide on fitting the led pods to the rear footwells in your ford.
you will require [/b][list]
[*][b]2 metres of cable (Sold in lengths of 2metre) [url="http://www.ebay.co.uk/itm/Twin-Core-10A-amp-12V-Black-Red-DC-Power-Cable-per-2m-/170680456683?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bd5915eb"]http://www.ebay.co.u...=item27bd5915eb[/url][/b]
[*][b]two led pods please choose from list in previous post in this topic[/b]
[*][b]roll of electrical tape preferably black [url="http://www.ebay.co.uk/itm/2-X-Rolls-FLAME-RETARDANT-PVC-Insulation-Tape-19mm-20m-/180483578968?pt=UK_In_Car_Technology&hash=item2a05a8dc58"]http://www.ebay.co.u...=item2a05a8dc58[/url][/b]
[*][b]stanley blade[/b]
[*][b]cable cutters [/b]
[/list]
[b]in this guide you will notice i have fitted some 3 led pods and the ones linked in the post above are 5 led their isint really much difference in the additional two leds under the footwell but i reckon the 5 led pods would give a slightly better effect. [/b]
[b]as you can see in the image below, [/b]
[b]the pods come from the supplier pre-wired with red and black terminals on the ends and 1.5metre of cable attached. [/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1923.jpg[/img][/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1921.jpg[/img][/b]
[b]i found the casing of the pods to be quite shiny and i wrapped them in a layer of black electrical tape to help keep them hidden under the rear footwells and not really noticable unless they are illuminated. [/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1922.jpg[/img][/b]
[b]first step:[/b]
[b]strip the ends of both red and black terminals on the end of both units and splice them togeather with one ond of the purchased 2 metre red&black 10amp cable. join the 3 black feeds to each other and tape them togeather using the purchased e;ectrical tape followed by performing the same action with the 3 red terminals. then tape the two bulk insulated cables togeather to create a Y shaped loom, ensure the red and black feeds are insulated seperatly before taping them togeather as one loom. [/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1925.jpg[/img][/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1927_1.jpg[/img][/b]
[b]if desired you can wrap the surround of the pods in black tape too, then fit one or two double sided sticky pads to one side of each pod. [/b]
[b]once complete, [/b]
[b]you can then bring the new wired loom with pods attached in to the car. [/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1928.jpg[/img][/b]
[b]un-bolt the centre console so as it can be lifted up to fit you hand underneath it, [/b]
[b]then begin to fish the cables under the seats on both sides ensuring that they are under the slide rails of the seats, [/b]
[b]leave around 2 inches of excess cable encase the units ever get caught on anything the cable is not likely to snap if their is a slight bit of excess their to allow for stretching, for example of a small umbrella was to be pulled from under the seat and it caught on the loom of the footwell light pod. [/b]
[b]do not stick the pods to the top of the rear footwell heater blowers yet because they may tear off with the fishing of the cables, [/b]
[b]wait to mount them correctly at the end of the process. [/b]
[b]next step is to locate the front footwell loom cables on the passenger side footwell, [/b]
[b]fish your rear footwell loom in to the front of the passenger footwell through the centre console. [/b]
[b]cut the excess cable from the rear footwell loom then like pealing a Banna. [/b]
[b]using your stanley blade gently peal back the positive feed on the existing front footwell loom feed. [/b]
[b]peel back the sleeving to reveal the copper internal and wrap the red positive around the front footwell stripped positive feed then tape it up with some electrical tape, [/b]
[b]and repeat the process for the negative feed. [/b]
[b]the front footwell loom cables should be Orange and Black [/b]
[b]so splice Red to Orange and Black to Black. ensure to do them one at a time because if the terminals meet then the fuse will blow and you may also need to get the code for the stereo so please ensure not to strip the two terminals at the same time. only stip one then tape it up before stripping the second one. [/b]
[b]finally the led pods in the rear will be illuminated if this guide was followed correctly. [/b]
[b]and you can position the as required while sticking the other sides of the double sided pads to the tops of the rear footwell blowers. [/b]
[b]the rear footwell lights will operate exactly the same and fade in and out in time with the front footwell lighting. [/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1930.jpg[/img][/b]
[b][img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1935.jpg[/img][/b]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image1131.jpg[/img]
Ash88lfc
Just ordered all this gear for the rear footwell lights. Hope they as easy as this guide sounds to do. Do i need to undo and take off the whole centre console lenny. never done this yet. is it straight forward?
[quote name='Ash88lfc' timestamp='1343342260' post='196845']
its simple enough mate,
pop out the caps on either side of the front footwells to reveal a torx screw, then remove the panels,
then lift the rubber base for the cup holder and remove the screws from their should be two torx.
finally open the centre console arm rest storage unit and remove the 2 front screws either side of the latch.
once removesd,
lift off the hand brake surround section followed by the cup holder section,
raise them up enough to fit your hand it its all you need.
and before closing it all back up ensure your 12v socket plug hasent come loose,
just push it back in again if it has.
Paddy H
Excellent again Lenny, iv ordered blue ones, swell as my ignition and the front footwell bulb holders. Really are a credit to those who are with no experience in car electronics.
[quote name='Paddy H' timestamp='1343469986' post='197116']
Excellent again Lenny, iv ordered blue ones, aswell as my ignition and the front footwell bulb holders. Really are a credit to those who are with no experience in car electronics.
Thanks mate,
its easy when you know what wires to splice in to.
Oxide
I can't figure out where the front footwell loom is, I've got everything taken apart and the cable set to go but no idea what I'm splicing them into...
I assume it's the same cables which are attached to the front footwell lights but they seem very short and disappear up into the dash somewhere.
Brigante
[quote name='Oxide' timestamp='1350828107' post='212809']
You need to take your glove box out mate. If you bare with me I'll run out n take a few photos showing exactly where your splicing into.
Oxide
No worries mare, did that and figured it out I. The end, got them working now and just have to mount them now!
Brigante
Right mate open your glove box door n remove the glove box. Should be 7 screws:
[IMG]http://i1256.photobucket.com/albums/ii487/therealbrigante/2012-10-21154237.jpg[/IMG]
Once that's out the way you'll be looking at this mass of wires:
[IMG]http://i1256.photobucket.com/albums/ii487/therealbrigante/2012-10-21154615.jpg[/IMG]
Flop this thing up so you got a clear look at things:
[IMG]http://i1256.photobucket.com/albums/ii487/therealbrigante/2012-10-21155000.jpg[/IMG]
And directly behind it you should find the 2 wires for the foot-well light:
[IMG]http://i1256.photobucket.com/albums/ii487/therealbrigante/2012-10-21155017.jpg[/IMG]
It will be easy to distingquish them from everything else as they'll be the only ones in the area wrapped in loom tape. So peal some of this back and you'll find em. Then just thread your rear foot-well light loom up though a gap in the from foot-well.
[IMG]http://i1256.photobucket.com/albums/ii487/therealbrigante/DSCN0838.jpg[/IMG]
Brigante
[quote name='Oxide' timestamp='1350831940' post='212828']
Damnit lol
:D
Oxide
Haha sorry, the pictures will definitely be a good addition to the guide though.
Got my glovebox light done while I was at it as well lol, and I found a better solution for wiring the aux in as well.
Just need to mount the led pods, not sure where to put them
Brigante
Lol last time I looked you hadn't commented again yet so I started typing it up n inserted the photos then soon as I posted it I saw you'd now commented.
Don't you have the blowers under your front seats mate? If you have just tape em on top of em.
What way you found for the AUX?
Was gonna say do your glove box light while your at it.
Oxide
I'll put it all in my thread so as not to spam lenny's guide
Brigante
[quote name='Oxide' timestamp='1350839489' post='212854']
Nice one mate. You found all the splicing n wiring in the rear foot-wells easy enough though?
Oxide
Yeah once I found the right wires it was a piece of [i]cake[/i].
Feel free to comment and add images as much as you want to mate.
My guides are in PDF format so pages of comments and banter won't affect the inital guide.
It may help others better understand it though.
vince_13
i ordered parts for this mod, and have completed the wiring loom and the bulb holders, now its a case of fitting it, on the previous page it shows a black and white wire and an orange wire, labelled for the footwell loom, however i couldn't find these wires in behind my glove box (hence making my own) so when connecting my loom
should i look for the same wires black and orange?
[quote name='vince_13' timestamp='1358699675' post='228657']
No Vince mate,
If you didnt have the bulb sockets, then you wont have power in the orange cable neither.
You now have two options.
Option A
Run a feed to the interior light loom
Splice blue for positive
Black for negative
This will power the footwell lighting when doors are opened etc.
Option B
Purchase an illuminated ignition ring light
The come supplied with loom to filter the cables on the interior light.
So you can splice the footwell lighting to the ignition ring .
vince_13
thanks for that glad i asked, ok well as it stands i currently awaiting my ignition ring (due the end of this month) so probably better to wait and splice into that loom (blue +ve, black -ve) and add in the new loom to the interior light,
[quote name='vince_13' timestamp='1358706658' post='228709']
No problem,
Better to wait for the ignition ring to arrive,
Because the loom on it has moulded connectors to filter the loom so you can easily splice in to it at the drivers footwell.
Please upload some pictures when complete.
vince_13
yeh shame it such a long wait :( yh want dya want to see, the splicing? just out of interest has anyone got a pic of the connection to the ignition ring? im wondering how far down im going to splice
[quote name='vince_13' timestamp='1358712535' post='228745']
yeh shame it such a long wait :( yeah what dya want to see, the splicing? just out of interest has anyone got a pic of the connection to the ignition ring? im wondering how far down im going to splice
The illuminated footwells
Splicing would be 4-5 inches down from the ignition key hole.
Peel the sleeve like a banna,
Wrap copper connection from footwell loom around it and tape seperatly with pvc tape.
vince_13
yeh np, just got to decided what colour leds bulb to buy now, :wacko:
If you look at the fitting guide on my signature the connections should be visible.
[quote name='vince_13' timestamp='1358713795' post='228750']
You should fit the rear footwell lighting while your there and waiting a couple of weeks anyways.
vince_13
thanks stoney,
and yeh lenny, the rears dont get used much so dont need the lights currently but its good that its only a couple of wires away :)
on a side note just ordered some blue Led t10 bulbs, should look nice with the blue ignition ring :P
Good choice. :D
vince_13
some bad news guys,
i removed the trim on both sides, fed the loom through, then tried to fit the bulb holders into the hole and lock it, then came puttin the bulb in and found that i had crsuhed the contacts inside and the bulb would not go in, :( luckily this was on the first of the lights so the other holder is fine, i wonder whether there is some hard plastic lock holders rather than rubber?
[IMG]http://i296.photobucket.com/albums/mm190/iesta90/20130125_131428_zps080ed6bc.jpg[/IMG]
With that holder you can push up on the wires and the contacts will slide out of the rubber bit.
That will allow you to straighten the contacts up.
vince_13
[quote name='Stoney871' timestamp='1359126678' post='230219']
excellent advice, thankyou now my bulb holder fixed :D maybe it be easier to push the wires out, lock the ruber in the mount and then pull the wires back through?
You may also find it will be a good idea to cut one pair of opposing lugs off the bulb holders as the holes under the dash only have two lug spaces.
Leaving all four lugs on means the holders don't sit straight.
I found this problem with mine and removing the lugs does help.
vince_13
thanks again stoney brilliaint advice :) hopefully if the weather holds on i might try again
All from experience mate :D
ungary
i got red bulbs x2 delivered this morning but im unsure how to remove the current bulbs in place and put the new ones in.
any help would be appreciated
gary
Wedge bulbs just pull straight out.
ungary
thanx stoney i will try and pull it out tomorrow. hopefully my map light bulbs will arrive then too.
so i dont have to unscrew anything to replace the bulb.
also i cant find the one on the passengers side.
gary
No unscrewing needed.
With passenger side do you mean no bulb there or no wiring?
If no wiring yhen it may have gone behind the dash panelling.
ungary
couldnt find a bulb there. i gotta get a fuse box cover too if i can find one. the cloth type one i have is ruined.
if it has gone behind the dash bord how do i get it back out
I have a plastic mesh type cover on my fuse box.
Can you see any light glowing anywhere from the passenger side to indicate where the holder might have gone to?
The wiring can't have gone too far, a bit of poking around will be necessary.
ungary
where u get it from. i checked it and can see the light but looks like its gonna be hard to get out
You may need to fish around with a bent coat hanger.
Rocky1966
I've just fitted lights to my 2002 focus, there were no wires behind glove box, so I spliced into interior light, and ran cable down A pillar
They fade in and out when door opened, but when totally switched off at interior light dome, the footwell lights still come on , when door opened, but they do fade out after time, is there a way round this? Because if I had the car door opened for say cleaning hoovering etc the lights would remain lit.
Hi Roy,
The way your foot well lighting currently functions is exactly the same as fords standard foot well lighting design.
The GEM automatically cuts power to the interior lighting after 30 minutes,
So if hoovering/cleaning with any door or boot door open for a duration greater than 30 minutes the GEM will cut the power to save your battery.
However if you would like full control over the foot well lighting you can fit a 12v rocker switch to the positive feed on the foot well lighting loom allowing you to cut the power flowing to them.
Purchase two insulated female spade connectors and a 12v rocker switch.
Cut the positive feed at a location where you would like the switch to be,
Fit a female insulated spade connector to each exposed positive cable,
Plug the crimped connectors in to your switch.
There you have full control of the foot well lighting to turn them off or in auto.
If you've used LED bulbs then the current draw will be small so having them on for 30 minutes will be of no impact overall.
+1
A 9v smoke alarm type battery will power an L.E.D for 9 years or something like that
I've got both front&rear foot well lighting plus ford logo puddle lights in operation on mine and never had battery trouble.
Whatever makes you happy though, tis your car mate if you want t fit a switch you can no worrys ;)
focusfan20
Where can I get footwell lighting please , I need wires and bulbs as I have nothing :(
Sent from my GT-N7100 using Ford OC mobile app
see page 1 of the guide for links to purchase the parts
http://youtu.be/RubBzkZzpUA
SeanW
Haha - mate of mine has just picked up a 59 plate Focus Estate...really wanted footwell lights so asked me to have a look
Bulb holders present, but no power to them lol
As it's a taxi, can't go faffing about with wiring lol
