anita-
February 15, 2009, 5:56 am
hi,
Im having a little bit of a problem with my girlfriends streetka.
All of a sudden the steering wheel has started to make what can only be described as a grinding/scraping noise when it is turned. it happens when moving and stationary.
If any one has had a similer problem or can shed some light it would be appreciated
Thanks in advance jordan
February 15, 2009, 1:55 pm
first thing to check would be the power steering fluid level as this often causes a grinding noise if it is low. if it is low there must be a leak someware that will need further investigation
Jax
February 17, 2009, 8:32 am
Hello there!
We are a ford ka family and both me and my sister have W reg KAs. We both have this same
problem it seems to come out of nowhere - mine did it just after being serviced so cannot be the
power sterring fluid. I dont think it is anything to worry about as it doesnt affect the general
handling of the car it is just annoying! My sisters doe it a lot more then mine and that has done
lower milege it seems to come and go but I wouldnt worry about it.
TheGrenade
February 4, 2010, 12:55 am
[quote name='Jax' date='17 February 2009 - 02:42 PM' timestamp='1234881121' post='12401']
Hello there!
The airbag slip ring behind the steering wheel needs some silicon grease this should fix the problem
ofaolain
October 19, 2011, 1:22 pm
[quote name='TheGrenade' timestamp='1265266501' post='63275']
Hi is this a job for a Garage of can it be done by a normal
btmaldon
October 25, 2011, 3:12 pm
A normal can do it. The noise is normally caused by a bit of grit or a piece of the mechanism getting stuck in the gap behind the wheel. As TheGrenade said, a bit of grease should do the trick.
