Full Version: Mk2 Cluster And Centre Console Updates
quadrophenic
Hi Folks,
Just been looking through the forum at some of the cool things people have done with their "foci" on here!
I have a mk2 57 focus ghia 1.6 petrol, just before the facelift came out.
I have done some searching and can't find out whether it is possible to first of all replace my instrument cluster with the 2008 facelift one (silver trims)
Ebay link below! It says on the page it is compatible but mine is the 115bhp and that isn't specified. Has anyone already done this?
[url="http://www.ebay.co.uk/itm/FORD-FOCUS-INSTRUMENT-CLUSTER-1-6-VP8V4F-10849-FE-VISTEON-BREAKING-SALVAGE-08-/160848898678?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AFord%7CModel%3AFocus&hash=item2573576a76#ht_1682wt_1344"]http://www.ebay.co.uk[/url]
Also I like the look of the newer centre console (like lennys!) with the 12v socket behind the gearstick. Is this a mod that can be done or is it a different size or something? Also is the wiring already there for the socket?
Thanks in advance for the help and keep up the good work!
Jonny
Hi, reference the cluster- I really don't know if it's compatible, I'm sure someone with a definitive answer will pop up.
Concerning the console, I'm pretty sure it's interchangeable, I have looked into it myself.
The 12v socket is easy to move, just access the original socket location in the cubby and either move it completely or patch off the cables and fit a second one.
I recently fitted a cubby ashtray unit(referred to on this forum as a garage door) and needed to move the 12v socket forward into the ashtray unit.
If you want to keep two sockets and have the ashtray fitted then all good, if you have the tray fitted but only want the one socket in the console then the best option to cover the old hole is get hold of a tray from a mk2.5 as it has no 12v socket and will tidy the cubby up.
quadrophenic
[quote name='Stoney871' timestamp='1343989350' post='198372']
thanks for the reply!
I've been looking for the cubby ashtrays! Where did you get yours from?
Sounds like a relatively simple mod then. Is there anything that provides a 12v to the back seats or is this a self mod job? The real reason for fitting the second one is for the kids DVD player. Really incovenient having the wires dragged from the front. Also want to keep the one in the "cubby" for my phone charger or sat nav.
Just checking your sig, i saw the 12v boot mod in the "how to" section. was it as easy on the mk2? i.e. is the wire already there?
Hopefully will get a for sure answer with the cluster cos they look sweet and not too expensive!
Preee
You can simply link the cables to the front 12v and place a socket in the back of the centre console.
The Cluster is not a straight swap , you would find most things would work but i'm sure it has to be coded to the car , there is a post somewhere on here regarding it.
The centre console if you can get one on Ebay , will be a straight swap , just make sure you get all the bits with it.
the dials are compatable however they need to be activated and programmed at ford i couldnt find a single one round my way who would even touch it and again the majority of dealers elsewhere wont touch it and if they do they insist on digital mileage correction at £150 the programming and fitting of the cluster and new software £175 labour standard rates at the garage usually £90 for the 2 hours add the cost of the cluster and you see why theres no point add to that all the features will not work . tampering with the mileage is something few garages want to do hence why many insist on the fitting and the mileage correction . rear 12v wires are all there as in the how to guides easy mod to do
Ashtrays do pop up on eBay from time to time but are not usually cheap unless you are lucky.
As I said, there are 2 types, one for the mk2 with a place to relocate the 12v further forward or the one for the mk2.5 that is just a smooth cubby without the socket location (no problem if fitted to a mk2 as people just make a neat hole at the back and leave the 12v in it's original location.)
It's easy enough to put a 12v in the rear of the console, just patch off the original one in the dash and as long as you don't overload the amps you will be fine.
The 12v in the boot is a doddle, there is a spare 12v live feed taped up in the boot behind the boot liner, you just need to run an earth to the car body (plenty of screws to put a ring crimp to).
For the definitive guide search the forum for posts from 'Lenny', he has a how to guide at the base of all his content and is also a great source of info concerning bits needed and availability.
quadrophenic
[quote name='artscot79' timestamp='1343991018' post='198381']
Devastated! I thought all the info would be on the ecu and the dials are simply a "readout" so just plug and play!
Looks like custom heater dials, new 12v sockets, possibly new centre console and new dvd hu will have to do for now!
It would appear my signature has possibly given you a bit of inspiration, if there is anything else there that you find useful or tempting, I'm on here quite regularly and am only too pleased to help if needed.
quadrophenic
[quote name='Stoney871' timestamp='1343991858' post='198384']
It certainly has, I saw the heater dials on ebay a couple of weeks ago but was worried about the quality but it seems like they are quite popular.
Might just use your sig as my new check list! lol
Not an led fan though so they might be skipped! ;-)
Thanks again, great forum, fantastic members
Even if you're not an led fan I can recommend a Q5 reverse light bulb aS it makes reversing in dark areas much easier.
I decided on led bulbs for everything but indicators (led bulbs tend to flash too fast unless resistors are also fitted) and headlight/sidelight bulbs.
For indicator bulbs a lot change them for silvertec bulbs as it gets rid of the orange tint in the bulb housing (detangoing as its called).
definately not plug and play im afraid
quadrophenic
In case anyone cares, I have done some more research regarding the cluster change and in the ELM how to thread it says it is possible but only if you can get a dealer to recode your keys to the new cluster. I have contacted my local ford garage and he said "I've never done it before but it should be quite easy!"
In conclusion he said if it was as straight forward as it sounds they will charge £55....job done! Now its a case of getting the ELM stuff and a new cluster!
it would be interesting my dealer had tried it once and it wouldnt work leaving them with a big headache hence why they wont touch it now as they said the car was unmoveable so they gave the guy a loan of a car to go home and get the old cluster so they could recode that one it looks simple but half the stuff if successful wont work
quadrophenic
What stuff do you think won't work?
If I get one sorted I will fit it to the car to see what works and what doesn't. The risk is that I pay for the cluster but then I can just resell it. As far as I am aware most of the options can be enabled using the ELM method. If the features work then I pay them to recode. Surely if it goes wrong it is just a case of putting the old one back in?
They must have a procedure for if a cluster is actually faulty.
yeah they put the old one back in if it doesnt work spoke to a guy round my way who has coded one before you should get the display working he said as he did it
quadrophenic
Well sadly I don't have the money this month so I will let everyone know if I take the plunge! More importantly I'll give as much detail as possible if I manage it!
dandabuctim
Hey Quadro,
Please do let us know if they manage to do it.
Also - whats all this ELM thingy, I used to recode keys for VAG cars etc, if its just some software and the Diagnostics port that is used - im sure I could do it (if its possible and the software is available).
I would also love to do the conversion - the MK2 ones look dreary and crap lol, my cousin who has a fiesta 02 - got into my car and said doesn't the dials and colours look shite, i was a bit peed off then lol.
Bugger - can see that this post was ages ago... nevermind.
quadrophenic
Hi Dan,
That is the strangest coincidence ever! I have just received my new cluster this morning! I had some trouble with a misleading ebay listing so that is the reason for the delay. Gonna try and fit soon and report back!
the elm config is all explained in a different tutorial thread. Good bit of software but it cant do the key programming required so it is sadly a dealer job.
dandabuctim
Im sure there will be some kits out there for programming the key :)
Ill have a delv about.
You will probably require a VCM/IDS terminal which with the software is mucho dinero.
quadrophenic
I agree Stoney, there is no publicly available software out there as it would allow anyone to reprogram the immobiliser! As you can imagine that would cause somewhat of a security risk!
You're looking at least £1500+ and the software licence on top.
Suddenly a Main Dealer or Auto Locksmiths prices look more reasonable methinks. ;)
programming the key would be cheaper via auto locksmith possibly £80 or more
Oh definitely.
Ford would insist on a diagnostic before touching your car, refuse to touch your self-sourced key and charge you for one of their keys at about £90, say the job will take four hours, take a tea break and a nap, and then call a mobile auto locksmith and charge you for the whole shebang.
An auto locksmith will cut, code and test your self-sourced key in probably five minutes (including the handshake before and after) and charge you £80.
The choice is obvious to me and exactly what I did when I added a spare flip key to my car (only difference is that I have a tame mobile auto locksmith that did it mates rates for me at £30.)
Anyone in the South West (Exeter and below) wants the guys number I'll happily pass it on.
quadrophenic
It isnt the same procedure from what I understand. I am not programming a new key, I am using my existing key and then programming the new cluster to communicate with the ecu. It is some sort of coding between the cluster and the ECU. This needs to be done by ford.
I have spoken to my local dealer and they agreed to give it a go for an hours labour, sadly I dont think I have a guarantee of success!
The only conditions they gave were that I had to have the cluster ready to remove, e.g. just unplug and that they had to see the old cluster in the car to verify the mileage matches.
I have the new cluster and when it is plugged in it all works fine, all the lights etc work, the display works fine just nothing happens when I turn the key. The idea is obviously to stop people very easily clocking it by changing the cluster.
Yep, definitely an ids needed for that.
BeerFuelledDude
Did they get it working for you then? Was it easy enough...or do you have any tips on what to say to the guy that would speed the process up?
Additionally, does anyone know how to get hold of the attached Focus cluster? It's the one with a slightly enlarged display - I've seen it on a Mk2 -> Mk2.5 conversion, so it is compatible
[sharedmedia=gallery:images:8588]
[sharedmedia=gallery:images:8589]
