Full Version: Rear Hub Bolts
MARLEY
Does anyone know where i can buy all 8 rear hub bolts for my Focus 2007 2.0L TDCI ?
Many Thanks
Paul
have you tried your local dealer? or www.fordpartsuk.com
im not even sure if these are available seperately tbh, surely they are
[quote name='MARLEY' timestamp='1344542719' post='200006']
Many Thanks
Paul
finis 1506577
comes as a 1 piece unit 5 bolts positioned on it. around £160 from the dealers.
you could also email some breakers on ebay.
MARLEY
Sorry meant to say the 8 bolts for securing hubs to rear of car
Thanks Again
[quote name='MARLEY' timestamp='1344544403' post='200019']
Thanks Again
as you can see below mate,
their is no part shown for the bolts you require although the image does display the locations for the bolts you require.
however your local dealer may be able to locate a part number for them and supply then to you.
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/discussions/Capture-4.png[/img]
MARLEY
[quote name='Lenny' timestamp='1344546281' post='200023']
[/quote]Hi Lenny
Would the bolts be part no HS1 ?
STEADS
I take it you have replaced both hubs/wheel bearings everyone i,ve done new bolts have been supplied with hub
MARLEY
[quote name='STEADS' timestamp='1344564028' post='200049']
[/quote] yeh replaced both sides but some are female torx and some male torx and different lengths too. was going to buy 8 new but all the same.
Regards
Paul
[quote name='MARLEY' timestamp='1344549920' post='200031']
Hi Lenny
Hi mate,
sorry for the delay in response the bolts HS1 are finis4501619
sold at £0.75 each and are size M10 x 30mm
MARLEY
[quote name='Lenny' timestamp='1344629983' post='200199']
Hi mate,
[/quote]Thanks for info mate,
is this the part no that any ford dealer would use ?
will go to Evans Halshaw Manchester Tues
Thanks again
Paul
[quote name='MARLEY' timestamp='1346077260' post='203571']
Thanks again
Paul
Yes the finis code was obtained for you using the same ford parts software as the dealers.
So they will know what your talking about if you quote the finis number
MARLEY
Hi Lenny
I have bought 8 new bolts from my local Ford dealer, the part number is now 1539719 and are £1.14 + vat each.
Many Thanks for your help
Paul
[quote name='MARLEY' timestamp='1346791390' post='204969']
Hi Lenny
Paul
No problem,
Ford must have been sick not being able to charge you over £50 lol
It seems my advise was usless to you though because the finis number you required is different to the one I quoted to you in previous posts.
But bottom line you got it all sorted out anyways.
maybe theres an update to the ECAT that you havent got yet. perhaps its part of release 80 that has all the fiddly bits!
Full Colour Version: Rear Hub Bolts
