craig'sfordcmax
August 12, 2012, 4:47 am
hi my cigarette lighter has stopped working
thanks craig
Preee
August 12, 2012, 4:51 am
First thing to check is your Fuse's , if your fuse's are good then then , it could be a loose connection or damaged socket.
craig'sfordcmax
August 12, 2012, 9:28 am
hi paul i have lost the plastic with the fuse grid. i bought a tool to check the fuses and it says that half of the fuse box does not work but works in other c-maxs
Preee
August 12, 2012, 10:32 am
What do you mean half the fuse box does not work?
If that was the case then more than your 12v aux would not be working.
If you don't know which fuse is for the 12v aux then pull them one by one to see if any are blown.
Remember some will not be live unless the Ignition is on.
