Full Version: Steering problem
Ford Owners Club - Ford Forums > Ford Models > Ford Escort Club
rodgerk
I've got a 1977 Escort GTI. Recently the steering seems to have developed a mind of its own. I keep getting little wobbles as if the front wheels are following the bumps and dips in the road. Also, when I change gear I get a slight pull to the right. I know I will have to get this seen to, but does anyone have an idea what may be the cause?
first i would check all the rubber bushes on the suspension and antiroll bar for any signs of play.
vinnyvangough
Its most probably your lower arm bushes.
You can have these changed but i found it easier to change the whole arm. It is a bit of a sod but worth doing. I changed mine on monday as i had this problem too.
gazwhite
[quote name='vinnyvangough' post='12634' date='Feb 19 2009, 08:19 PM']Its most probably your lower arm bushes.
You can have these changed but i found it easier to change the whole arm. It is a bit of a sod but worth doing. I changed mine on monday as i had this problem too.[/quote]
I think i may have the same problem.
How much would this cost to get done?
bungle318
i also seem to have this problem, but my lower arms seem to be fairly new with no play
bungle318
[quote name='bungle318' post='14886' date='Mar 12 2009, 09:39 PM']i also seem to have this problem, but my lower arms seem to be fairly new with no play[/quote]
changed mine today and it has sorted it, turned out there was some play in the rubber bushes. quite an easy job :rolleyes:
gazwhite
[quote name='rodgerk' post='12513' date='Feb 18 2009, 05:27 PM']I've got a 1977 Escort GTI. Recently the steering seems to have developed a mind of its own. I keep getting little wobbles as if the front wheels are following the bumps and dips in the road. Also, when I change gear I get a slight pull to the right. I know I will have to get this seen to, but does anyone have an idea what may be the cause?[/quote]
I had this problem with my escort 1.8si. I have just had my wishbones changed at that seems to have sorted it. hope this helps
vinnyvangough
Its only around 25-35 per arm so well worth doing it.
bungle318
[quote name='vinnyvangough' post='16454' date='Mar 25 2009, 11:36 AM']Its only around 25-35 per arm so well worth doing it.[/quote]
got mine for 18.25 each from my local factors
bungle318
[quote name='batateam' post='16554' date='Mar 26 2009, 08:39 AM']why???????
-------------------------------------------------------------------------------------------------------------[/quote]
dont know what you mean?
vinnyvangough
[quote name='bungle318' post='16689' date='Mar 26 2009, 10:13 PM']dont know what you mean?[/quote]
Not to worry mate, spammer
blamberton
i had this problem last year with ma gti except it was pullin to the left, a got the wishbone replaced and that sorted it :D
kobie24
Hi guys, has anyone got a guide to changing the bushes on an Escort GTi. My steering is pulling (I think both ways) quite violently, usually when i'm doing high speeds. I had the same problem about 18 months ago & the bushes sorted it but was done at a garage. I'm a novice so need something fairly stagihtforard to follow. Cheers, Chris.
Full Colour Version: Steering problem
