Full Version: Central Looking Problem
RichJones
One issue fixed now want to try and get another fixed
All doors lock with the Key fob
All doors lock with the turn of the key
All doors unlock with the key fob
All doors unlock with the turn of the Key
Now this doesn't happening all the time and when it does it may only happen once or could happen 5 or 6 times
Open the car with the key fob as normal get in start as normal start to drive off and i will hear a noise as if the car is trying to unlock. Like i have a sticky latch
Will maybe make this noise once or like this morning 5 times
Ive Lubed up the latches with Graphic Lube changed the batteries in both key fobs
Any ideas anyone Wire issue maybe?? Lock latch on its way out ???
Thanks for your help :)
RichJones
Oh and more info
I dont have a Auto lock after 10mph thingy on my car. Its a 2005 model which i dont think has this
Mike77
Have this problem on my 2006 model too, its suppose to be something to do with water getting into the main central locking unit in the drivers door,,, through a faulty door seal. I've not got round to checking it out yet though. Though I do think it could be correct because when we have heavy rain, my kick panel below the door is quite often wet...
+1 on that, a common problem.
RichJones
So what the fix ??
Plenty of WD40 for a start.
If it's got obvious corrosion them probably a new unit.
May be worth fitting a new sill rubber too.
RichJones
[quote name='Stoney871' timestamp='1345741369' post='202876']
When you say plenty of wd40 where do i actually spray it ???
Is a new unit cost lot ?? Rubber seal i assume ford sell this ???
Sorry for all the questions
Spray anywhere you can find a gap.
Ford will sell spares but usually insist on fitting them too. Mucho dinero.
RichJones
[quote name='Stoney871' timestamp='1346175531' post='203810']
Sorry gonna sound a really silly question again but anywhere i can find a gap???
Down the rubber seal or the actually lockin latch ??
Even just spraying the outside of the lock unit will help to remove moisture.
If in doubt spray it.
RichJones
Heavy Rain last nite and the bloody locks had a hiss fit today
So sprayed every gap i could find with WD40 but now looking down the new unit route
What are the prices for a new unit ?
Is it a ford job or can anyone do it
Do do i remove the door panel mk2 Focus
Full Colour Version: Central Looking Problem
