Full Version: Ford Cd6000
talksy
Hi, my 2009 Ford Focus has a CD6000 head unit which looks like this:
[img]http://www.mp3avto.si/wp-content/uploads/sony2.jpg[/img]
If I was to purchase one of the better head units from ebay (the one with Satnav), would I just simply remove the old one and put the new one in, plus enter in the radio code? Or would I need to program the new one in? Would the ford bluetooth that I currently have running on the car still work? I am coming from using a Vauxhall where head units had to be married and programmed into the hid in the dash.
Any advice would be really good. Not sure if I am definately wanting to, just getting ideas :)
021C
An upgrade should be a simple case of plug and play assuming that you [b]A.[/b] go for a a unit out of the same model car i.e. focus to focus and [b]B.[/b] you have the appropriate aerial for the upgrade you intend to do. In the case of the Sat Nav unit you'll need the GPS atennna (which I think is built into the aerial base and mast) This may also require a new loom from the aerial to the head unit. Alternatively an alternative GPS antenna could be placed in an alternative location - inside dash for example.
I changed my Sony single CD for a DAB version - this was a simple swap (as I bought a version from a similar age focus) I did, however have to purchase a new aerial mast, base and 2 part loom to accommodate the DAB connection. [b]Cost £85[/b]
Bluetooth should be fine as the information is held in the module.
As said previously, the key to changing the radio is getting a model from the same or similar age model to reduce the chances of incompatibility.
Others have done the upgrade from the 6000 + fitted bluetooth so should be able to comment further.
Stu
Full Colour Version: Ford Cd6000
