Full Version: Front Screen Wash
stevebowser
The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full.
zetec521
[quote name='stevebowser' post='12712' date='Feb 20 2009, 06:11 PM']The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full.[/quote]
Clean the jet washer with a pin. It is probably blocked.
jeantech
[quote name='stevebowser' post='12712' date='Feb 20 2009, 05:11 PM']The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full.[/quote]
the only thing i can think of is the nossle is blocked try clearing it with a pin also put some screen wash liquid in it
SierraYankee99
Get the car on some nice dry ground, give it a good squirt. Get out and see if your cars wet itself {big puddle under the side where the washer reservoir is}. If it has, probably the pipes blown off the pump. It happens a lot on fords especially if the wash freezes and you try using the washers.
Russ
Would have thought the obvious thing to do would be to take the pipe off from the nozzel under the bonnet, squirt the washer and get someone to see if water comes out the pipe! If so the jets blocked, if not then either the filter in the bottle is blocked or the pipes come off at the bottle.
gaz6076
[quote name='Russ' post='13747' date='Mar 1 2009, 11:21 AM']Would have thought the obvious thing to do would be to take the pipe off from the nozzel under the bonnet, squirt the washer and get someone to see if water comes out the pipe! If so the jets blocked, if not then either the filter in the bottle is blocked or the pipes come off at the bottle.[/quote]
Would have to agree. If it isn't a blocked jet its most likely the bit gauze in the washer bottle behind the pump. Common problem in the fords unfortunatly.
Full Colour Version: Front Screen Wash
