Full Version: P1344 ???
ford escort van 75 turbo
Has any one had this before.
its on a 2002 mondeo 2.0 tdci 130
the car has lost power and smokes like a trooper.
it misses bably too.
This is what the fault finder found:
P1344 Pedal Demand Sensor C Circuit Range/Performance (see 2131)
U1900 CAN Communication Bus Fault - Receive Error
P2339 Cylinder #4 Above Knock Threshold.
any ideas peeps.
are you using the right scanner for a pre 2004 diesel as the u1900 code suggests that the codes could be misleading?
[font=arial,helvetica,sans-serif][size=4]It sounds like you've blown a gasket, valve stem seal or a piston ring.
I'd get the cylinder head checked as it really sounds like oil is getting in.[/size][/font]
[font=arial,helvetica,sans-serif][size=4]What colour is the smoke? Black would mean unburnt diesel whick would basically loss of compression on one or more cylinders, blue would be burning oil.[/size][/font]
[font=arial,helvetica,sans-serif][size=4]White is either steam or smoke depending on if it smells of fuel or not.[/size][/font]
[font=arial,helvetica,sans-serif][size=4]Have a read of these sites for better info.-[/size][/font]
[font=arial,helvetica,sans-serif][size=4][url="http://www.kent4x4offroading.co.uk/smoky_diesel_engines.htm"]http://www.kent4x4of...sel_engines.htm[/url][/size][/font]
[font=arial,helvetica,sans-serif][size=4][url="http://www.ehow.com/facts_5020340_diesel-smoke.html"]http://www.ehow.com/facts_5020340_diesel-smoke.html[/url][/size][/font]
the smoke is unburnt diesel, had it started earlier and lots of grey smoke and a bit of black too, think its a injector down..??
Full Colour Version: P1344 ???
