mberry77
September 17, 2012, 3:32 pm
Hi, my wifes ford focus had front brake discs/pads replaced on 101k miles which was October last year.
In about May this year (on 108k miles) the car was juddering when braking, took it to garage and front discs/pads were replaced as i was told the discs were warped.
For the past few weeks the car is juddering again, now on 111k miles we're by told by local garage the front discs are warped and need replacing.
Really? Is something causing them to warp or is it actually something else?
STEADS
September 17, 2012, 4:00 pm
[sup][size=4]WHERE ARE YOU GETTING YOUR DISCS FROM COULD BE A CASE OF JUST POOR QUALITY OR THE ONLY OTHER THING I CAN THINK OF TO MAKE THEM WARP IS EXCESSIVE HEAT I,E BINDING BUT I SHOULD THINK YOUR CALIPERS WOULD OF BEEN CHECKED BY WHOEVER FITTED YOUR DISCS AND PADS IF ITS BOTH I,D LOOK AT THE MANUFACTURE [/size][/sup]
September 17, 2012, 4:23 pm
as above, check the calipers out - sounds like they could be binding to me
September 17, 2012, 4:53 pm
If you're getting excessive pad wear then I'd say binding as well.
