indiadog1
September 28, 2012, 8:56 am
Hi. My 1999 mondeo estate only has one key and it looks different to the keys in the manual. Mine has only two buttons on it , one with a triangle and the other with two. I've took it to pieces to fit a new battery but it had 3 in it, and the manual said it has one cr3032??. Also over the little bulb is a red piece of plastic and a 4 digit code number and sticker. Can Anyone help at all with this ?. Dont know whick batteries to fit etc.
ppeter7
September 29, 2012, 11:16 am
hi there this might be of some use to you chap as theres diff setup look at bottom of this to see list of keys on link.
the 4 didgit is the code for the key regards pete
Obtain all keys fitted with remote control.
Turn ignition switch from position 0 to position II 4 times within 6 seconds.
Turn ignition switch to position 0.
The system will emit an acoustic signal to indicate start of programming mode.
Programming mode activated for 10 seconds proceed as follows:
Press and hold lock, unlock or boot release button.
Wait for acoustic signal (indicates correct programming).
Repeat above procedure within 10 seconds to program remaining keys.
To exit programming mode:
Turn ignition switch to position III or wait 10 seconds.
[b] Source(s):[/b]
Autodata
http://www.mirez.co.uk/Keys.htm
chrismaybury31
October 10, 2012, 6:05 pm
Hi Peter,
do you know if this process works only for new keys or will it work for reprogramming a second hand key
Thanks in advance
Chris
October 10, 2012, 6:13 pm
The posted procedure will set the key up to operate central locking but [b][u]WILL NOT[/u][/b] programme the transponder on a second key for the immobiliser.
