Full Version: 2006 Focus Dipped Beam Failure - Both Headlights @ Same Time
Shimster
Hi All
Driving home last night, both my dipped beams failed at the same time. The high beam works fine, and no other electrics are suffering issues. I understand that the headlights have their own fuse, so I'm thinking that both fuses or bulbs failing at exactly the same time is not the case (could be wrong though!)
Has anyone else has this problem?
Shim
Never had this problem myself, have you checked the fuses?
If you don't have an owners handbook, look to my signature for a link to fuse locations and ratings!
Shimster
I am shocked and stunned!! Both bulbs had failed at exactly the same time. Is this an indication of any other possible issues?
It is usually recommended to change bulbs as a pair anyway.
I have had it before that one blows and gets replaced and the next day the other one goes too.
Pitmonster
[quote name='Shimster' timestamp='1349297977' post='209549']
Had the same thing happen on a Citroen Xsara. Changes both bulbs and never had another problem.
