estate_fan
October 16, 2012, 5:14 pm
Just noticed my aux socket is not working. How do I go about removing the radio unit to see if it's even plugged in? (Oh yeah, mine's a 6000CD in mk2.5)
leftathome
October 17, 2012, 2:46 pm
I`ve got a late mk 2 estate and the 3.5 connector is missing in the glove box. If that is where yours is situated it maybe quicker to look there as oppposed to taking the radio out first. Just a suggestion.
estate_fan
October 18, 2012, 1:04 am
ok thanks, I do have a ssocket in the glove box, maybe it's not connected.
Oxide
October 18, 2012, 5:08 am
I'm sure there is a guide on here somewhere on how to remove the 6000cd radio. I have previously heard of people who have a 3.5mm aux in port which simply isn't connected.
Brigante
October 18, 2012, 12:13 pm
On the mk2.5 I believe the head unit surround simply pulls off, and then there's 4 torx screws and the head unit should just pull out.
A member did it here when fitting an after market head unit:
[url="http://www.fordownersclub.com/forums/topic/36712-aftermarket-head-unit-fit/"]http://www.fordowner...-head-unit-fit/[/url]
The gear leaver surround doesn't need removing I don't think.
On the mk2, the head unit has to come out first using 4 removal keys in the slots n the head unit simply pulls out. Once it's out then the head unit surround just held in by torx screws.
Either way, the head unit is easy to remove, n once it's out the way it should be easy to see if the aux lead is connected or not I would assume.
Brigante
October 18, 2012, 12:18 pm
By the way, in that link it's on a mondeo, but on the focus 2.5 it's basically the same where the surround simply pulls off n then it's just a few torx screws holding the stereo.
Oxide, how did you remove your surround when you carbon wrapped it?
Oxide
October 18, 2012, 2:32 pm
The surround just takes a bit of brute force and ignorance, you can use a flathead screwdriver with some cloth around it to prevent scratches and then just pry it off going from one side gradually around to the other. Feels very fragile but you can't be too gentle with it.
Definitely don't need to remove any other bits of trim on a mk2.5 to get the radio out.
October 18, 2012, 2:45 pm
[quote name='Oxide' timestamp='1350588772' post='212382']
You bring the brute force, I'll provide the ignorance. (some self effacing humour there)
estate_fan
October 18, 2012, 5:52 pm
Will do that,thanks
Oxide
October 18, 2012, 9:52 pm
[quote name='Stoney871' timestamp='1350589514' post='212386']
When it comes to fords I think it's the other way round mate
October 18, 2012, 10:25 pm
I can fix anything, except I've run out of bodge tape and can't find my hammer.
Oxide
October 19, 2012, 5:58 am
Golden rules for DIY:
1. If it moves and it's not supposed to, use duct tape
2. If it doesn't move and it should, use WD40
3. Anything else, use a hammer
johnH
October 19, 2012, 3:27 pm
you forgot 1 rule:
4. always carry a list of curse words for when you hurt yourself.
October 19, 2012, 4:43 pm
Rule 5, if you can't stick it, unstick it or beat it into submission, walk away and deny all knowledge.
Oxide
October 19, 2012, 5:57 pm
[quote name='Stoney871' timestamp='1350682991' post='212581']
And don't tell the Missus what you're doing so she can take the pi** when you fail miserably
October 19, 2012, 5:58 pm
Very true.
estate_fan
October 21, 2012, 12:26 pm
Got it working today, turned out cable wasn't plugged in behind glove box. Must have been previous owner putting parrot handsfree.
BTW how many digits is radio code? There'sa number handwritten on the casing, wondeeing could be it...
Brigante
October 21, 2012, 12:28 pm
Thought that would be the case where it just wasn't plugged in.
Radio code is 4 digits
Aux In Not Working
