Full Version: Turning Off Engine Management Light
lpoolm
Hi, I have a focus diesel 56 plate.
Can anyone tell me how to turn engine management light off other than taking to a garage.
Long story short had a faulty sensor which I have changed now car runs fine but still has engine management light on as needs resetting!
I have read unplugging battery can do it (tried for 10 mins but light still on).
Or is there a fuse for the engine management light, I do not have a manual to check fuses unfortuantly.
Any advice would be great thanks.
Mike77
Needs plugging in basically mate, to erase the code, not much else you can do afraid :blink:
I believe there's a sequence involving the pedals when turning the ignition on but not starting the car.
Found it.
Try this and see how you go.
1. Close all doors. 2. Turn the ignition key to position II. 3. Simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 15 seconds. 4. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed.
ferretfloozy
try driving around for at leat 30 mins so it completes a full check then park up (engine stopped) for 5 mins worked on my fiesta before i bought a reset/reader
STEADS
where about in cheshire are you got a scanner that willl turn it out bfor you if your n ear by
lpoolm
Thanks for the replies, going to give the pedal pressing a go in a few minutes, will update if it works!.. or if it doesn't!
(I am in St Helen's by the way)
STEADS
if you coming down ellesmere port/chester way in the near future give us a shout pm me and i.ll sort it for you .
lpoolm
[quote name='STEADS' timestamp='1351158811' post='213553']
Thanks for the offer mate, I work at Cheshire oaks so always down that way!
Anyway I tried unplugging the battery - does not work
Also the pedal thing, did not work either.
Anyway I was very lucky to have a friendly local garage that turned the light off with no charge so very happy now!
Thanks for all the input and advice, I do like this forum, lots of helpful people!
STEADS
no probs if it comes on again give us a shout the oaks is right on my door step 2 mins away
