Not sure if this is the section to post this,
I have a 2007 Focus 1.6tdci style bought from a Ford stealership March this year. After a month had a starting problem it went back to Ford who found a fault with a module that powered down the dash. They replaced the module & put me a new battery in, everything was fine untill this weekend, Sat morning it would not turn over but the electrics worked, I got it started with jump lead & went to my local garage who do all my repairs on my other car. They tested the battery & said it was all good there must be a drain somehwere. Any ideas what the problem could be, do you think Ford should should do the work under warranty as the previous work should be under warranty still?
