Full Version: Mk2.5 Headlight Aligning
Rh1no
Hiya folks,
Kind of figured out that the problem with my dipped beams are the actual headlight unit alignment and not the bulbs. I have secured the headlight in the correct position using the single screw as per normal, but they are still aiming far too low. How do I ajust this?
You should have adjusters for each light, usually a screw inside a plastic hexagonal hole that you can adjust with an Allen key
Rh1no
Tried this but it doesn't seem to do anything, am I missing something? :(
Haynes is a bit vague when it comes to light alignment.
They just tell you where the adjustment screws are and then promptly tell you to go to a garage to get them done.
Haz93
There are two alignment screws on each headlight, the one on the top appears to do nothing but it actually adjusts the headlight left and right. The second one is harder to get to but it is this second one that adjusts up and down. One turn will move the lights only a very small amount. When I was working in land rover they used electric screwdriver like things with the Allen key end, linked up to a light sensor to position them correctly. Maybe you could make an Allen key to fit an electric drill to speed up the process but it would be best to leave it to a garage to do
Rh1no
Thanks mate, will be taking it to a garage next week :)
Rh1no
Took the car to a reputable local independant garage this evening who tried to ajust the headlights but could not do it.
The man said that the motor is not working, when he was turning, nothing was happening at all.
He reckons I may need a new set of headlamps as they are a sealed unit?
HELP :(
Haz93
Had something similar happen in my dads Yaris when I just passed. It's only a ball joint that holds the levelling adjusters to the light reflectors and can 'pop' out of place when removing bulbs, big speed bumps etc... If you take the bulb out, and get a finger in the hole (yes I know what I just said :P) and pull the reflector towards the adjuster it should 'pop' back on
That may not be the case but will save some money if it is :)
Rh1no
[quote name='Haz93' timestamp='1354145963' post='218862']
I will give this a go, fingers crossed.
Rh1no
Still not got round to this, but the car is having a well overdue clean tomorrow so will give it a shot, fingers crossed.
martyntdci
hope you get this sorted mate, fingers crossed for you
Rh1no
[quote name='martyntdci' timestamp='1358115069' post='226577']
Same here pal. I have the MOT at the end of the month, will probably fail on wheel damage, so the last thing I need is to buy new headlamps too :(
All of this before I can even Tax it and put on my private reg :( meh!
martyntdci
have a read of this
http://www.fixya.com/cars/t3401107-align_or_focus_headlights_beams
Rh1no
Cheers mate will have a read. Hoping they can be sorted.
Full Colour Version: Mk2.5 Headlight Aligning
