Full Version: Can't Find Power Steering Fluid Resovoir
Drich290195
Can't find it at a on my 1.8tdci mk2 any ideas where it is guys thanks
k13r4n
try taking out your driver side headlight by removing the silver screw then there are two catches you will be able to see and reach one to the right nearer the engine and the other is at the top you will need a long screwdriver to get this one lift out the light and should be underneath thats where mine is hope this helps.
Drich290195
Cheers mate will have a look later thanks took my lights of the other night I find it easy to unclip just pulls out but can't pull the cable of the light any suggestions
k13r4n
The wire harness should come out not sure how but it does haz93 or some of the other members will know as I haven't done this myself
[quote name='k13r4n' timestamp='1351962127' post='215049']
[quote name='k13r4n' timestamp='1351971724' post='215082']
The headlight loom plug sleeves over the headlight socket and is held via plastic moulded clip,
Seperate clip from catch and pull,
Not easy but also put a towel on the bumper under the headlight to avoid the headlight unit scuffing the bumper when removing the loom
