[quote name='homeless' post='19432' date='Apr 11 2009, 07:08 PM']It will work all you have to do is give it a 5-10 min drive @ a constant 40mph ish and the system will relearn it's self, if you have it displayed via you info display on the cluster so it shows you the pressures the out of pressure one should show up as a blank bar...this will change to the correct reading after the short drive.
The other way is to input the tyre pressure sensor code/number via an IDS unit @ a Ford dealer.
Or alternatively just leave it and just make sure its @ the correct pressure before fitting it...this will not harm or damage the system.
hope this helps...not bad for my first post if i say myself
Hi Thanks for all the replies.
I have now sourced a full size alloy rim to take on my trip. I have had two new tyres put on the front and salvaged one of the tyres to put on the spare alloy rim. The tyre people said, that if needed, I could put the spare on, but it will not have a tpms sensor, so the display should just show it as a blank reading.
