Full Version: Aircon Focus C-Max
Mabbs
Hi
Own a 2004 (54) C-max and Aircon is not blowing cold air. It is newly re-gassed.
I was looking at the fuse diagram and see that 'Aircon Clutch Solenoid fuse' is missing from slot 15 of the under bonnet fuse box (F1510a).
Since I have never been in the fuse box and not sure anyone would actually need to can anyone tell me if the fuse is really needed?
Mabbs
If the system has been recently worked on and is not working then how did they check the system?
Part of the process would be to run the A/C and check temperatures at the vents.
Without the clutch solenoid fuse in place the pump would not engage therefore no compression of gas and no coolant will cycle.
I would suggest you return to the person who did your A/C and make enquiries.
NorthSussex
[color=#0000ff][size=5][font=comic sans ms,cursive]You could have a leaking aircon condenser or compressor resulting in a loss of gas. It needs a dye put through the system to check for leaks, this should have been done on the re-gas.[/font][/size][/color]
Full Colour Version: Aircon Focus C-Max
