Full Version: Guide To Removing/installing Sony Stereo - Mk3 Focus 2011>
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Focus Club > Ford Focus Guides
iNath
After this (successful!) upgrade yesterday I thought I'd share some helpful photos if anyone wanted to attempted the same :)
Here's what you'll need:
[img]http://img593.imageshack.us/img593/7239/dscf2558e.jpg[/img]
Step 1: underneath the stereo in the center is a small plastic piece of trim, you need to remove this to expose the screws underneath:
[img]http://img39.imageshack.us/img39/4620/dscf2567jw.jpg[/img]
[img]http://img607.imageshack.us/img607/6180/dscf2569l.jpg[/img]
Step 2: remove the 2 screws:
[img]http://img507.imageshack.us/img507/4566/dscf25662.jpg[/img]
Step 3: Pull the whole unit towards you taking care then all clips are released. Try to pull out vertically as not to bend or snap anything. You'll need to unplug a cable that goes in the back of the controls so don't pull it out too far.
Step 4: The screen is held in by the 4 screws highlighted in green, the stereo by the 2 in yellow. Remove these and pull outwards:
[img]http://img855.imageshack.us/img855/1102/dscf25722.jpg[/img]
Step 5: Remove the plugs from the screen and CD player, then refit in reverse!:
[img]http://img405.imageshack.us/img405/4630/dscf2573t.jpg[/img]
Here's the screen in:
[img]http://img202.imageshack.us/img202/1523/dscf2581c.jpg[/img]
And the finished article, before and after:
[img]http://img202.imageshack.us/img202/9274/dscf2562o.jpg[/img][img]http://img13.imageshack.us/img13/1874/dscf2585d.jpg[/img]
[img]http://img203.imageshack.us/img203/5501/dscf2586j.jpg[/img][img]http://img831.imageshack.us/img831/8962/dscf2587o.jpg[/img]
Also here's a comparison of the old (blue) and new (colour) screen side-by-side:
[img]http://img811.imageshack.us/img811/3910/dscf2575x.jpg[/img]
[img]http://img252.imageshack.us/img252/6759/dscf2578n.jpg[/img]
I notice the colour screen has an extra input (top middle) - not certain but assuming this might be for reversing camera?
jimrex
Thanks Nath :D
Preee
Unfortuantely the reverse camera requires not only a harness but a little black box to decode the video , [u]so i'm led to believe [/u], but when i took mine out i only took the stereo out and not the screen so i will take it out and have a look at the back of the screen and try an AV source on it see what happens.
i have seen guides saying to use pliers on the insert to pull out , DO NOT USE PLIERS , a small flat screw driver flips it out easy.
good guide iNath
Steve
I have added this to the guide section of the club as well mate.. cheers for sharing!
Greg Sayer
Hi, looks good,
where did you source the Sony unit?
any problems if you only have the low level (blue) screen in the instrument cluster? or with voice control etc???
Preee
[quote name='Greg Sayer' timestamp='1357397732' post='224597']
Hi, looks good,
Should be a straight swap and voice should be fine
mayo10uk
Hi guys, i've just swapped my metal for a 1.6 econetic, with satnav I have both colour screens and interested in the reversing camera, any sucess with the av input on the main screen.
Preee
[quote name='mayo10uk' timestamp='1357404918' post='224617']
The is a wiring harness required with a signal converter box also required, and i'm not sure if there is also another box required in the boot
mayo10uk
Checked my friends focus earlier he has a power outlet in the boot, im guessing this can be retro fitted easily i hope.
mayo10uk
Thanks, the addition of extra boxes would seem an expensive addition. :mellow:
May give this a miss, any other additions I could add, looked earlier seems foot-well lighting is a no?
I think I can change interior lights to maps lights found some on ebay earlier.
Thanks lovely the econetic, and economical driving :)
Preee
[quote name='mayo10uk' timestamp='1357425666' post='224675']
You can fit footwell lights by using a wire feed from you center interior light , you don't have to try and use the OEM wiring.
Greg Sayer
anyone know where you can actually get either the sony DAB or a ford SatNav unit?
iNath
Ford dealer (£600+) or try your luck with breakers yards.
mayo10uk
[indent=1]Nath with your experience with IDS, have you done any mods to MK3 focus.[/indent]
[indent=1]I have the FORD NAV system with dual colour screens, I am thinking of adding OEM parking sensors,[/indent]
[indent=1]however a map displays on centre console, I am guessing it will have to be activated in the software.[/indent]
[indent=1]Any advice please?[/indent]
mayo10uk
Would be nice for a reversing camera toooo, I'm thinking this will be too costly.
iNath
I'm currently experimenting with automatic lights/wipers on a MK3 Zetec-S, any findings will be published on here ;)
Other investigations will be powerfold mirrors, ambient lighting, cruise control, and any other parts I can get my hands on + a willing volunteer with donor car!
jmbrown91
[quote name='iNath' timestamp='1358976521' post='229734']
Nath we've already decided to add all that to the list of attempts on the ZS ;)
mayo10uk
There maybe a solution to my problem with OE parking sensors and display.
Ever heard of this set up?
[url="http://www.celsusice.co.uk/shopdisp_6077.php"]http://www.celsusice.co.uk/shopdisp_6077.php[/url]
james_60
Nathan i will be a donor ie guinei pig
As you know i would like cruise control activated etc
Jamie
Graham M
Thinking of buying one of these units to go in my Zetec S when it arrives, if I can pick one up from a breakers do you need to get a code to go with it?
Graham M
It's ok I've just found a reply in another thread that says they are plug and play!
iNath
Correct ;)
iNath
Correct ;)
