Full Version: Keyless Entry - Rear Sensor Fault?
dstewart
I wonder if the rear keyless entry sensor on my 2010 Focus is dying?
In the past couple of days I've noticed the lights flashing when I approach from the rear of the car. Experimenting tonight I find that if I bring either keyfob within a foot of the rear switch then the car continually re-locks. (Single or double depending on what I set originally.)
Up until 10 minutes ago the driver and passenger buttons had been behaving normally - I've been out checking it's staying locked! On the last attempt it seems that the doors open okay, but won't lock unless I use the remote.
It does sound like something has died! Any idea what the fault might be, and what sort of price I'm looking at when I go to the garage?
One final question. Should you be able to double lock from the rear button? Mine only ever single locks, but I vaguely remember it double locking just after I got the car last spring.
k13r4n
yes u can double lock from rear of the car as I can do it with my keyless button I would check you car battery first most local garages should do this free then take matters from there
dstewart
Thanks k13r4n. It's good to know I wasn't imagining things! The double locking problem would have started in June or July last year, so I suspect the battery is okay. Can't hurt to check though. Touch wood it's just a faulty rear sensor/switch and easy to replace.
k13r4n
hopefully it's an easy fix could be the module that's packed in let me know how u get on
dstewart
It was a faulty rear switch. And it's covered under the warranty :-)
k13r4n
goof stuff glad to hear u got it sorted
