Sst99pro
December 28, 2012, 7:01 am
Hi all,
I hope the forum can help me here. I have had water ingress in the luggage area of the boot boot of my Focus estate for the last 3 months. Over that time, it has been into the dealer 3 times and the leak has still not been fixed. The have done the following:
-Put sealant round the tailgate hinges (a common source of ingress apparently)
-Had the roof lining away and still not been able to pinpoint the leak source
Alas, this has still not fixed it and water is still coming in though the rear plastic 'vents' on the inside of the rear pillars. Taking the tailgate seals away and looking inside the (soaked) lining indicates water is still coming in from somewhere, and the lining is soaked up to 2-3 inches from the top corner of the tailgate. This might indicate that the leak is coming from that area. This problem is occurring in both the right and the left hand side of the car, bust mostly on the left.
My car also has t-track roof rack fixings.
I really hope someone can help me here! The car is perfect besides this.
All the best and a belated Merry Christmas to you all!
December 28, 2012, 7:23 am
[quote name='Sst99pro' timestamp='1356699716' post='223132']
Hi all,
Welcome to the forum,
This is a common fault on the hatch models including ST where the seals around the spoiler bolts wears away allowing water engress,
Ive removed my rear spoiler and applied silicone as a preventive action,
May be the same on the estate, not sure if yours has a rear spoiler section.
NorthSussex
December 28, 2012, 10:38 am
[color=#0000ff][size=5][font=comic sans ms,cursive]If it has a sun roof, this can be the cause as the drain pipes get blocked and water leaks into the rear of the car.[/font][/size][/color]
[color=#0000ff][size=5][font=comic sans ms,cursive]No sun roof? check the rear washer pipes and connections.[/font][/size][/color]
December 28, 2012, 12:14 pm
Check around the roof rack mounting points too.
The seals there can perish or work loose too.
jon-v8
December 28, 2012, 1:53 pm
Have you check the foam seal on the rear of the light clusters?
I had the same issue with my estate, I found that the rear cluster wasn't fitted correctly at the dealers - they trapped wiring loom between the cluster and the pillar (not tucking the loom into the pillar correctly), this then allowed water to get into the boot and fill up the small box section in the corner. Mine eventually overflowed into the wheel well!
My fix (So far it has worked), was a couple of beads of silicone around the cut out on the rear pillar, allow to dry and harden and re-fit cluster.
craig281986
December 30, 2012, 10:29 am
Hi guys
New to the forum and having problems with my Mk2 Focus 1.6 Petrol. I discovered the drivers side rear seat was soaked one day and due to heavy rain here before ive had the chance to get it looked at the water has been soaked up on the base of this seat and the middle seat, also the lower back rest.
I checked the floorwell and its fairly damp along with the boot floor and spare wheel well. I cannot see where its coming from. I have no sunroof, the door and boot seals dont seem wet and no visible tear or anything.
Is there a common problem i should be checking before i let the garage take a look and rip me off?
Craig
December 30, 2012, 11:41 am
[quote name='craig281986' timestamp='1356884975' post='223440']
Hi guys
Craig
Hi Craig,
Welcome to the forum, This is a common fault on the hatch models including ST where the seals around the spoiler bolts wears away allowing water engress, Ive removed my rear spoiler and applied silicone as a preventive action,
See the Guide section of the forum for information on removing the rear spoiler, very easy process,
Dont forget to place a blanket on the roof under it though encase it scratches the roof when you un-bolt it.
Once removed,
Dry the whole area,
And apply standard DiY bathroom silicone around the bolt holes and along the top of the rear window,
Dont worry none of it can be saw when the spoiler is back in position,
But the leak will be stopped. Ford would do exactly the same thing and charge you perhaps two hours trouble shooting fee because they dont admit its a common fault on all mk2 & mk2.5 hatch models from 2005-2011.
Thats what i would do, but ya gotta stop for a moment and think...
"What Would Jesus Do?"
December 30, 2012, 1:00 pm
Have to agree the spoiler is leaking if its getting on the seats or rear boit hinges
Sst99pro
January 14, 2013, 5:58 am
Hi All,
Looks like I have solved the problem and the garage that hasn't been able to fix it has refunded my money in full (as exoected). Here's what I did.
My Mk. 2 Focus Estate has 'T-Tracks' on the roof to enable fast *cough* fitting of roof bars etc. They have a very loose fitting rubber seals around the edge between the bodywork and the base of the tracks. They also have gaps in between the sections which I believe were letting the water in.
I hence put silicone sealant round there and filled the inside behind the seals and let to dry for at least 24 hours before taking the car out again. I also removed the inner roof lining in the car and sealed up 6 gaps which the drips were originating from.
I then let all that sealant dry before applying another layer to ensure the seal was tight, and hy presto, no water ingress.
Also, as a precaution, as well as previously sealing up the roof hinges, I sealed up the gromits for the cable and tube entries for the rear lights and screen wask respectively. Just remove the gromits, put seals round them, and replace, leave to dry, job done!
Hope this helps anyone else who was in this dilemma!
All the best and thanks for all your help.
